Compressor troubles
Compressor troubles
Steven Antonucci
Compressor troubles
steve antonucci
>Looking for the collective wisdom of the group to see if there something that can be done to resolve a compressor issue. My compressor is "kaflooey".
But not in the normal sense of kaflooey. It runs when I turn it on, and it has a digital counter on it that registers that the tank is getting filled. The tank does pressurize, but when I hit the business end (any air powered tool) it is not working (or just for a second and then nothing).
I think that there's some kind of computer malfunction in the digital thingy that is telling the the output side that it's empty. It's a Husky from Lowes, and probably just out of warranty. Figures, right?
Any one see this before?
Steve
First in line with Husky Tech Support on Monday...
Re: Compressor troubles
>Loosen the drain plug. If there's air then the problem is not in the tank it is being filled. The problems must be somewhere else. I'm not familiar with that model at all. Mine has a manual guage.
Dave Anderson (PacNW)
>If there is pressure in the tank, try a new air hose I had onetha the liner collapsed one
arkie
>By all means, loosen the drain plug, if you have not already done so, and drain out any fluid that is there. A large accumulation of water can produce symptoms similar to those you describe. Unlikely to be the case and unlikely to be so severe, but very easy to check and fix if it is.
Walta
>Please be careful there is a lot of potential energy stored in that tank! Do not remove the drain plug from a pressurized air tank as it could strip the last few threads and go flying and take a chunk out of someone or something. I like the plugged hose theory.
Walta
Ken Oakley-Sunny St. Cloud, Fla.
>I would suspect a faulty line regulator
Texian
>Agree with Ken. Your regulator is stuck closed and not allowing pressure to the air line/hose. It leaks just enough to pressure up the line/hose for that one little puff.
Steven Antonucci
Is it "fixable"?
steve antonucci
>Assuming that I drain the tank, and open the cover, is it something I could deal with myself?
If I can fix it, I will. I hate to have to pay for it, since it would probably cost as much as the unit did.
S
Re: Is it "fixable"?
>Steve That's what I ran into. At the time I was broke so replacing the regulator was cheaper than replacing the compressor but not by a whole lot. If I had to do it over I would buy a new compressor. I couldn't get the exact replacement so I had to jury rig this one. It does work however and may last longer than the original.
GalenV
>There are a lot of good ideas, so not sure what you tried yet. I would think the tank would have a petcock and not deal with a plug to check if tank is truly pressured. All tanks should have a pressure relief valve with a manual pull ring that is another way to see if you have air in the tank. Pulling this ring periodically is in the manual I am sure to insure it works when it needs to. A bad diaphragm in the pressure regulator will many times bleed air to atmosphere and if you do not hear it leaking then like they say it could just be stuck. Yes it pays sometimes to give the regulator a rap to see if it may break it loose.
Most units have an adjustable regulator so if you open it up you may blow out a small plug. Some small regulators can be take apart and see if you can clean. There will be spring pressure on at least one side of diaphragm so hold pieces together while removing screws on the bonnet or the bonnet may unscrew on small regulators.
If it is a differential regulator it will have a small vent hole to atmosphere that you could see if it is plugged. A bad diaphragm would normally leak air out this vent.
I assume the check valve from the compressor to the tank is working or it could leak air from tank back into and out of the compressor. Sometimes this is built into the head or other times looks like a fitting in the line. Some are mounted right at the tank.
If the tank is not getting air it could be the digital pressure gauge is just ahead of the check valve and only showing pressure build up in the line to the compressor. These check valves can be taken apart too many times. Some are just a simple ball and spring.
Your parts list may not show regulator or check valve break down and if so you may have the buy the assembly.
I guess I am way out of dated if your unit is digital display.
Windy I am.
don lewonczyk
>Hey Windy what did you have for supper? Couldn't help it! Digital stuff is out of my league but I would first drain the tank,then turn compressor back on make sure you have a lot of air volume coming out. Stop compressor put plug back in or close petcock, disconnect air line (out going pressure side) turn compressor back on making sure you have dialed up say at least 90PSI and if air comes out and should since there is nothing to stop the flow then it very well may be your hose collapsed. If nothing comes out then it more then likely as not to be your control board. What do you have on the end of your hose? A blower? Is that what you were using when nothing came out? If thats the case I would check that first as it may be obstucted. I would still drain the tank anyway as that is a good practice because not only do you keep water out of you airhose you help the tank from corroding inside. Good Luck, DonL
Steven Antonucci
More info (thanks for the two ideas...)
steve antonucci
>I did unplug and replug the compressor in. No change after "reboot".
When the compressor is running, sometimes it shows pressure building (numbers going up on the readout) and other times it just reads zero. When it stops running, the correct tank pressure is displayed.
I also opened and closed the drain valve several times and it is pressurizing the tank. When I open the valve under the tank, it has a significant amount of air.
I will look at the hose (I only have one)first, and if it doesn't work, then I'll try to look at the regulator.
Steve
Don- 10 different heart pills could you tell
GalenV
Re: Compressor troubles - - diagnostics
Pete LaBelle
>Let's break down the compresser unit to determine where the problem lies:
1) If the drain or relief valve is opened and you get a lot of air (when you think you are supposed to have air), you are making air. If no air comes out, you have a compressor head problem.
2) No air out of your hose? Remove it from the compressor & check for air flow. If you have a quick disconnect at the compressor, just plug in a male quick disconnect fitting and you should get lots of air. If you do, your hose is the problem. If no air, most likely a regulator problem.
3) Is your regulator turned all the way clockwise to open it fully? Might also be that your gauge is bad, and reading 100 psi when it is only in fact reading 5 psi. Have seen this before. This can be proven by dumping all the air from the tank and seeing where it zero's out to.
4) If everything points to the regulator, with the air hose open to atmosphere, crank the regulator to full open, then close, several times to maybe break it loose.
5) Most regulators are pretty simple devices. You may have to take it apart and look for crud or broken parts. Unfortunately, most compressor manufacturers have "special" regulators that will cost you dearly to replace. If your current regulator is proven bad, can it simply be removed, or the guts removed, then place a regulator down stream of the old one? Check with friends who work in factorys. They normally have access to used regulators for cheap or free.
Good luck. Let us know what you find.
Pete
Steven Antonucci
Thanks-Recap (now working!)
steve antonucci
>I assume that the issue is somehow electronic, with the problem being somewhat intermittent. I redrained the tank, and disconnected the hose and just plugged in a blower nozzle. I ran the tank up to about 15 pounds and hit the blower. Lots of air.
I then reconnected the hose, hoping that it would not work (and ready to just put the nozzle directly back on the tank), but it did, so the hose is good.
At this point, I think the issue is in the electronics, since in my experience, mechanical issues tend to be "somewhat permanent". I've had this issue for the last couple of weeks, and I was 'living with it" because I was busy with other things.
Interestingly enough, I bought it at Lowes, and when I called their Service Advantage support number, they sent me to the wrong manufacturer first, and then couldn't figure out who actually made the unit. Finally, they found someone who might have and gave me a local service number to look at repairing it. It was the wrong number, and I ended up connected to a jewelry store.
I'm probably going to live with it, and I may just pop the hood open on it to play with all of the mechanicals if (when) it goes out again.
For now, I have air.
Steve
