Ideas... What can I make with these?
Allen Neighbors
>I posted this pic on another forum, and I'm really looking for someone's brain to pick. I think I'll be making a beading tool out of one of them, but a machinist, I'm not. :(
These are 6 1/8" blades for a Craftsman 6" Jointer. A friend gave them to me. They are new, and HSS.
How to cut it for little Tear-drop scrapers?
How to drill a hole in it?
Thanks for your ideas.
Re: Ideas... What can I make with these?
>I suppose there must be a way to drill them but what I would do is use a cut off wheel and grind a slot into them. Easier to do and you don't have to remove the screw to change cutters, just loosen it.
jwoodwright
>Allen,
A water jet can cut that like butter! 50,000+ psi! Check the yellow pages... You'll pay a set-up fee and per each. Great thing is there should only be a one-time set-up fee... Future ones should only cost a few bucks. This way the steel remains tempered and the hole is precise. John K.
Barry, that's a nice idea!
Allen Neighbors
>That's what I like about this forum. Good ideas abound! Thanks for taking the time.
Allen Neighbors
>Thanks for the idea, John. I'd be willing to bet there isn't one of those things within a four hour drive of me. That's how far it is to Fort Worth and Oklahoma City.
Unless I don't know what I'm looking for. There's nothing in our little 1/4" thick phone book. :)
>I bought one of the expensive drills to drill a hole in the stuff and then came to the same conclusion. Just cut a slot. It's faster and works better.
>Allen You can buy an angle grinder from Harbour Freight or Northern Tools for next to nothing. Then buy a cutoff wheel and a grinding wheel for it. You can do an awful lot of shaping with those two tools. Just take light cuts until you learn how to control it.
A good file or Dremel tool with abrasive wheels work well for final shaping.
Here's what I made...
Dominic in Buck's County PA
>Allen,
I used the exact same blades to make the marking knife pictured below.
Photobucket
I cut the blade with an Dremel and abrasive cut off wheel. I shaped the bevel edge on a grinder (with frequent soaks to keep the metal cool).
With some of the scraps I made blades for my small shear scraper. Again, I used my Dremel and an abrasive disk.
See ya around,
Dominic
Dick Hines
Dick Hines
>Allen I got a couple a while back and made two scrapers. One has a square end and other is square on the end with a scraper ground on the side. I use this one when I make small boxs to get the lip on the opening perfectly square.
It also works great when I do hollow froms and hollow through the bottom. By useing it I know that everything is lined up correctly and that my glue joint will be perfect.
Ken Oakley-Sunny St. Cloud, Fla.
>I have snapped hi-speed saw blades by wrapping them in a heavy cloth,
clamping it in a heavy vise exposing the amount I want off and giving it a hefty whack with an 8 lb sledge hammer or a really big ball pean hammer. Sometimes it takes 2 whacks.
Shear Scraper
Don Orr
>Binh Pho makes shear scrapers from old or new planer blades. They are easy to break by scoring them with a cutoff wheel in a dremel and holding in a vise and hitting with a hammer as someone else mentioned. He mounts them in a slot in the end of a round bar and secures them with a set screw. For this method you do not have to drill the HSS. I have one of his and they work well. You can use a staight section on the outside of bowls and grind a curve for the inside of bowls.
arkie
>If you *must* have holes, you can get them with a carbide burr, a little lube to keep things cool, and a little patience. It's good to know which HSS steel it is - I've made knife blades of all hard power hacksaws (M2 or M4). Blueing these during grinding doesn't seem to hurt the temper or hardness like it does others.
What I would do
Don Evans
>Try to contact a machine shop - or welding shop and see if one of them has a plasma cutter.
Take something thin like a cereal box and make a cut out of what I wanted, shape size etc...
Then take them to them and have them do the cutting and if they don't want much to do the grinding on edges I have them do that also.
If they want too much for the grinding I would still have them do the cut outs and I would do the clean up and at same time sharpening with the bench grinder.
The plasma cuts so nicely there isn't much clean up, you'd mostly just be shaping edge and sharpening at same time.
Why plasma, very little loss of material and they could also do the slotting for the screw hold down.
Lots of luck
Don
Thanks, to everyone, for the ideas.
Allen Neighbors
>I'll give some of them a try, and see how it comes out. I'll post a pic of the ones that work. :)
All of you are appreciated.
Al
