Re: Live center thread?
Chuck Engstrom
>I'd suspect strongly that your PM thread is really 3/4" x 10tpi. One inch is 25.4 millimeters, so your reading of 10mm diameter comes out to .7874 inches, just a hair over 3/4", and 2.5mm per thread comes out to 10.16 threads per inch. Go to your local hardware store and get a 3/4-10 nut and see if it fits OK. If it does, 3/4-10 taps are pretty easy to come by.
5/16 and 8mm are also easy to confuse, 8mm larger by only 0.0024 in. I once worked on a Lucas diesel engine starter which, I remain convinced, had one stud of each, and I was extremely lucky to figure this out before I screwed up the threads of either by taking a wrench to the wrong nut. That would have been a several hundred dollar mistake.
BSW is Brisitsh Standard Whitworth, a British thread standard: http://en.wikipedia.org/wiki/British_Standard_Whitworth.
Best to all --
Chuck Engstrom
