End grain sealer
End grain sealer
End grain sealer
Jerry in Indy
>Looks like there aren't too many people on line today, everyone must be taking their spouses shopping. Anyway, I worked up a couple of logs today and then found that my end grain sealer was pretty solid. Just wondering if there is any way to put it back into liquid form or if there might be someone in the Lake Geneva, WI area I could borrow a pint from. Thanks in advance.
Jerry
Re: End grain sealer
arkie
>I'm in South Milwaukee, and would gladly lend you a pint. Alternately, you could probably pick up a fresh gallon from Chris at the Woodcraft Supply store on 108th. He's a good guy and sponsors our turning club, which meets there Monday evening.
>Jerry,
Did it separate from the water, solid on top? Depending on how bad you might remix it by shaking vigorously. Anchorseal is a wax/water emulsion which will tend to separate if it freezes. That's what they told me when I bought a 55 gal drum so I got the kind with antifreeze. I still had some separate but it mixed up again OK. If it just dried out I don't know what to do.
BTW, if you use a lot or want to share with other turners even a 5-gal drum shipped from UC-Coatings is still a lot cheaper than buying it by the gallon from Woodcraft.
As well as Black Friday, I heard on NPR this morning that it was also National Buy Nothing Day so that's what I celebrated. Made shavings, took the horse trail riding, fed the chickens, did nothing useful. Life is good.
Electric Drill... Paint stirrer....
Allen Neighbors
>That's what I use every year. My shop is not freeze resistant :o) and my 5 Gal buckets of Anchorseal freeze at least once a year. I put my paint stirrer on the drill, and mix it up. The bubbles will eventually rise to the top, and it's as good as new.
If it's too thick, you can add a little water, but I wouldn't add too much... if it's too thin, it takes too many coats, and too much time.
