A55 Smoothing Plane
OT Batteries
OT Batteries
OT Batteries
mfoster
>Hi all. I have a battery pack for my Airstream that seems to have died. I decided to open it up to see if I could replace it with regular NiCads. It would be do-able but I found that the batteries are 3 D size in series. I looked online and found that a battery pack is available with 3 D size in series that cost 25% of what Airware wants. I'm ready to jump on it, but find the specs aren't exactly the same. The airware pack is rated at 3.6V and 5.7 amp hours, the one online is 3.6V and 4 amp hours. Seems like it should be OK coupled with the smart charger I have, but wondered if anyone knows more than me. TIA
Mike
Re: OT Batteries
Re: OT Batteries
>Mike,
I don't know what kind of charger you have, but typically the battery of the same voltage will be charged to whatever it will take and simply won't run as long during use. Be careful of the connectors.
I've seen nicads Ds from 4-8 amp hrs. Some chargers will work with nimh cells as well which can be higher capacity.
Another thing you can do is take your battery pack and charger and specs to a local battery store, if you have one. The Batteries Plus near here will rebuild nearly any battery pack to the original specs for a reasonable cost.
Re: OT Batteries
Re: OT Batteries
Brian Hahn in SW Wisconsin
>The batteries you are considering will only last 70% as long at the original batteries before needing to be recharged.
Get two battery packs and you'll be money ahead. Charge one while you are using the other.
Re: OT Batteries
Re: OT Batteries
Scott Hurley in N VA
>If you have a Batteries Plus store in your area, they may be able to rebuild your battery pack with better batteries for less than many other options.
Scott
Re: OT Batteries
Re: OT Batteries
Jim Sebring
>I had the folks at Batteries Plus rebuild a battery pack for my 1992 vintage Airmate 3 a couple of months ago. The new batteries are just a bit lower in amp hours than the old ones, but run and recharge just fine. The two sources for new packs I could find wanted $100 and $125, respectively; the rebuild cost me $32.19, including a 9% sales tax. I figger I won this round!
Re: OT Batteries
Re: OT Batteries
mfoster
>Thanks for the help. I figured amp hours translated into battery life. I live in rural VT, so there is no chance I'll find a Batteries Plus store. I did find a battery pack online with slightly better specs for slightly less $ and ordered 2. I already have a backup battery pack so I can have one charging while using the other, and I'll have a third pack for when the next one goes.
Re: OT Batteries
Re: OT Batteries
Barry Turner
>I have had very good luck with Battery's Plus rebuilding rechageable drill batteries for about one-hald what a new battery would cost.
