>I was blessed to have a friend of mine give me a rather large cherry burl. It was cut right out of the tree about 30" long by 36" wide. Any Ideas of how to cut this thing to get the most out of it? I like to turn bowls and hollow vessels. I would like to get a large bowl out of it.
>I do not have the ans,but hopefully the inside will be fine. I've had some rather bad luck lately with a walnut crotch pc. The layers(maybe shakes) were kinda de laminating -for lack of a correct word. pw
>Cherry Burl wood is some of the most fascinating/beautiful/interesting wood anywhere. Cutting them up isn't all that easy, as there can be all manner of infoldings, crevasses, bark inclusions, etc...
If you can provide a few different views, you'll get some helpful advice here. Are you interested in utilitarian (flat-top) bowls, or are you considering natural-edge bowls and vases, too? Are you equipped to core this beauty to get multiple pieces from it?
Hollow forms usually require some depth of burl, or you can get creative, and make an HF at the intersection of burl figure and straight grain wood, placing the burled figure where you want it. I find most burls will yield either a good-sized hollow form OR a larger bowl, but I have had some large enough to make a big bowl, a medium bowl from the core inside that, and a medium HF from the core inside that bowl.
