Picture size
Picture size
Picture size
Jerry Klug
>John K Jordan and Bill Crommit were helpful in my learning how to post pictures. The file handle is a rudamentory project I did when I got my lathe. I just needed a photo to test to see if I got the instructions right.
Re: Picture size
Re: Picture size
Paul Waddle
>I still can't post pics. I can't get picture at or below 80kpix(?)Boo hoo....pw
Re: Picture size
Looks like you did just fine
Cyril Griesbach
Re: Picture size
Steven Antonucci
If you run any Microsoft OS
steve antonucci
>Download and install the Image Resizer from power tools. You simply right click on a picture and say "make smaller".
You should be able to Google the application.
S
Re: Picture size
PT link  *LINK*
ILYA ZAVORIN
MS PowerToys
Re: Picture size
Re: If you run any Microsoft OS
Randy G
>Thank you and Ilya for that... I had never heard of it, just downloaded it.
Re: Picture size
Re: Picture size
Don at Central Illinois
>The picture is fine, size wise, etc. and the hanldle look very good also.
Re: Picture size
Dick Hines
Re: Picture size
Dick Hines
>If you have Adobe Photoshop pull up a picture then go to image then resize. Change your setting to 6' x 4.5.It should work upload then.
How about that Carole, me giving someone computer help!
Re: Picture size
There's only one problem
Allen Neighbors
>with Image Resizer. If you ever do anything to the picture before re-sizing, like cropping for instance, it won't work. You have to wait until you resize before enhancing the image. As long as you do all your enhancements in-camera, it's a wonderful tool.
With MS Photo Editor, you can reduce it to anysize, anytime, but it's not as easy to use as Image Resizer.
Re: Picture size
Image Resize in Photoshop
>>...Change your setting [in Photoshop] to 6' x 4.5. It should work upload then.
Dick,
Yikes, I assume you meant 6" instead of 6'. I used to do images that were printed 8' wide and more, but I retired and quit that. :)
A comment on this - specifying a size without specifying a resolution is meaningless, or perhaps I should say "insufficiently defined". For example, a 6" image at 72 pixels per inch is only 432 pixels wide. One at 144 pixels per inch is 864 pixels across, while one at 300 pixels per inch would be 1800 pixels wide, a bit too big for comfortable viewing on most monitors. It's generally best to specify the pixel dimension and ignore inches and resolution.
BTW, when images are printed is usually the only time necessary to consider a resolution number (in DPI or PPI).
Back to the Photoshop Image Size dialog box, for posting we might set the Pixel Dimensions to around 600-700 pixels in width, first making sure "Constrain Proportions" is checked. The image height will be set automatically to the correct number. Ignore everything in the Document Size group. The other option in the dialog, "Resample Image" should default to "Bicubic" which is the the best quality resizing algorithm in Photoshop.
Regardless of size, the JPG will still have to be saved at a quality level to fit in 80K. Since we are assuming Photoshop, the easiest way I know to do this is use the Save For Web option on the file menu and tell it you want 80K - it will usually end up at something like 79.8.
One word of caution which might not be obvious for those not familiar with editing photos on the computer - NEVER save the resized image over your original photograph file or you will lose it without a backup or at least cause confusion! In fact, even without resizing, every time you load a JPG image and resave it you lose a bit quality due to the compression.
One thing I do to keep up with a edited image is save it with the same file name but append a descriptive tag to make it unique. For example the reworked original GREATBOWL.JPG might end up as GREATBOWL_ecs.JPG to remind me that this version has been edited, cropped, and sized.
Re: Picture size
Dick Hines
Re: Image Resize in Photoshop
Dick Hines
>John I am lucky to figure out how to resize let alone change all that other sutff. Comnputers drive me crazy. Cooking an apple pie is another thing all together. Speaking of apple pie I have one in the oven as I type.
It will be better than anything I can do on a computer. Sorry I do now mail my pies.
Re: Picture size
>Will trade near infinite amounts of computer graphics work and/or instruction for one good apple pie. Mailing is not necessary - I'll call in a Delta frequent flyer ticket for the cook and have all the ingredients ready.
We just baked a cushaw pie Wed and it's almost gone today - way better than pumpkin and I love pumpkin. Not as much as apple, though.
