Made from a piece of Jarrah that was given to me by Darryl B 2 years ago.
No I haven�t been working on this piece for that long but it seems like it.
Measuring 12 inches 300mm square by only 40mm thick this was a bit of a challenge to get one wing up and three down
Because of the thickness I had to hot melt glue a waste block onto both sides.
Kelly would have had a heart attack seeing this spin around held on by hot melt glue
The process was as follows
� Glue on a waste block to what will be the top, and using a screw chuck into the waste block true up the base .Turning the bottom of the bowl with a small bump that will become the feet .Carve the feet you can hardly see them on this piece. sand and finish the back .Including the down wings
� Turn a waste block to fit over the feet and hot melt glue onto the base .True up waste block.
� Flip the piece over and turn the up wings
� Turn the vee in-between the wings
� Cut off the wings not required
� Turn the inside of the bowl to form the splash
� Sand the splash, sand the splash sand the splash until a glossy finish is achieved. As this grain is fairly porous it took a long time to get down to 2500 grit by oil sanding
� Carve away the wings to form the drips
� More sanding ,more sanding and just for fun some more sanding ,when you think you have finished spend another hour sanding
� Undercut the drips
� Texture the wings with a dremel ,remembering that any marks left from carving will show through the texture .So for fun spend some time sanding to 400 grit
� Stain the splash and drips with a none grain raising stain ,sand with the 2500 grit re-stain and sand again
� 25 coats or was it 26 of lacquer were sprayed and sanded between each coat to achieve depth to the water/oil look
� So the name The Last Drop ,could it be because of the oil crisis or because it used up the last drop of my patience
� I have seen other splash pieces one being Martin Edwards ,hopefully I have added my own touch .
� I think I will revisit the drop as I think it needs to have more of a stretched look .This is number three and I still didn�t get it right ,dammed if between centres it looks fine but when stood up vertical ?
� Every know and then I pop out a piece that gives me the shivers ,this was one of them
>I think you don't sleep at any time dreaming up your creations. Mighty fine work, I like your style Terry, you have shown us some of your work and its all interesting. Keep it coming. DonL
