Sphere cutting rig
Sphere cutting rig
Sphere cutting rig
>I love the Vermec sphere cutting rig. Is that a Hunter tool on the tip or just a round scraper? I may have to try and build one of those. I built a wooden one years ago but it lacked the fine adjustment of the cutter and wasn't very rigid. I think I copied the one Mark StLeger made.
Re: Sphere cutting rig
James McClure
>I haven't heard of that one. Do you have a picture or a web link? Sounds interesting.
Re: Sphere cutting rig *LINK*
>Sorry I meant to post the link.
http://www.vermec.com/id1.html
Fred Holder
>Hello John,
I've had one of Vermec's Sphere Cutting Rigs for about two years now and use it to turn 2-1/2" balls (spheres) for making the Chinese ball. It does a very good job. Yes, the cutter is a carbide cutter like the Hunter tools use. The only down side to the use of the carbide cutter in this rig is that you cannot rotate it to 45 degrees each way to obtain the best cut possible from the carbide cutter. It still cuts nicely and is a very well built rig, very solid.
More Woodturning Website
Re: Vermec sphere jig
bob elliott
>Some nice features about the Vermec: the cutter shaft is micro adjustable, the unit is rock solid and smooth (main shaft rotates on a bearing). Since the cutter is oriented flat, heavy cuts cause tear out. Micro adjustment comes in handy when making the down hill cut. When I reach the end of that cut, I can back off the cutter 1/4 turn and come back up hill and make a 1/2 (or less) turn shaft advance for the next cut.
When I first got mine, I spoke with Hunter and got one of his cutters as a spare. He does not supply Vermec though.
>It looks to me like it wouldn't be very hard to make the cutter rotatable so you could do the initial cuts and then rotate it to about 45 degrees and make a final pass. I don't know if this would be a true bevel rubbing cut or not but since the tool is captured it shouldn't matter.
