THE WOODRAT IS BACK!
Photo attachment question
Jerry Klug
>I tried to post a message with photo but my pictures have about 8X too many kilobytes. Is there a way to copy the picute and reduce the bytes so I can post it?
Re: Photo attachment question
Re: Photo attachment question *LINK*
>Jerry,
This is asked periodically - the last time I remember is in the link below.
I use Photoshop for this which makes it easy and I understand from the thread that the newer versions of Paint Shop Pro also make this simple.
But you can reduce the size to under 80K with any photo or image editing program. Basically, you:
1 - crop as much as possible
2 - resize as desired - Image/Resize (640 pixels wide is a good size)
3 - save the file as a JPG
When saving, most programs let you pick a quality or compression level. It may take a couple of attempts to get the size right, but try reducing the quality level until the size on the disk is less than 80K. If your software specifies a "compression level" instead of a quality, increase this number and retry.
If you continue to have trouble, mention here what software you are using and someone may provide exact instructions. If you don't have any image software, some free programs are available - I think one is mentioned in the thread below. If you want to post a few and can't get them reduced enough, feel free to email them to me and I'll be glad to adjust them and send them back to you.
http://www.woodcentral.com/cgi-bin/messages3.pl?re
Woodcentral FAQs *LINK*
>I almost forgot there is a pretty good article on posting pictures on the Woodcentral FAQs page. (link below)
Check FAQ #7 "How do I resize photos so they will be under the permissible limit for uploads? (external link)" Ignore outdated info about a 40K limit. FAQs number 6 and number 8 may also be useful.
Scroll down to the bottom of the FAQ page for a DIFFERENT writeup on the same topic: "Q: How do I resize pictures so that I can post them on Woodcentral?"
Also, for more information than you may want, try a search of the archives here and on the message board. An example is this thread: http://www.woodcentral.com/cgi-bin/messages3.pl?read=372493
BTW, unless I'm going blind, the WC FAQs are difficult to find! For example, you can get there by going to the "LINKS" link on the home page (or in the menu at the left under "Departments") - FAQs should be the second item in the long menu bar at the left. I suspect the FAQs are not easy to find because they are disorganized and some are hopelessly outdated. Anyone with extra time and an interest in such things might volunteer to see if Ellis would like some help rewriting them.
Woodcentral FAQs
bill Crommett
>Jerry: I use "fast image" to reduce my pictures to 640 X 480 for sending them by e-mail. Fast Image because that is ALL it will do. It is a simple drag and drop application. It won't correct for color or brush your teeth or turn on the microwave. It just reduces a picture to your specifications.
Jerry Klug
>I got the photos to post. How do they stay in the same thread like I normally see them? Do I open the first and post the second photo as a response?
That's the simplest way
>If you host the pics elsewhere you can put image tags in your post calling as many pictures as you like. That's not difficult, but you need to know the drill. We'll be happy to show you, if you want to learn.
Cheers,
Ellis Walentine, Host
Dinyar Chavda
>I use the free Image Resizer Powertoy for Windows XP.msi --one source is:
http://www.esnips.com/doc/c818f61d-0dd8-405b-8931-531c6635aa59/Image-Resizer-Powertoy-for-Windows-XP
A similar product for Vista is at:
http://www.vso-software.fr/products/image_resizer/
although I've never used it.
Once installed, you can right-mouse click on any image, and it will give you options on various sizes--I think I usually use the small for WC.
>>multiple photos
1) Read the FAQ I mentioned - it gives instructions for remote hosting. I don't like this method since it can leave orphaned messages in the archives with no photos.
2) Post in successive messages. clean, simple, works
3) Send to Dan Donaldson who has offered to format multiple pictures for posting IF they are of general usefulness to a number of users. I guess he decides.
4) Combine the pictures yourself with an image editor. Thats the method I prefer. Example below.
>>>question for Ellis, with photo samples
>Ellis,
I've been meaning to ask you about this. There are two potential problems with hosting pictures elsewhere then combining them into one nice message. One, as mentioned, if the hosting site goes away the messages are left without photos in the archives. I've found several very nice but useless messages like that. Two, some people don't have the resources or whatever to put photos on a separate site.
If you created one additional "photo" forum here to go along with Messages, Turning, etc, people could post messages there, out of the way of the normal threads, then reference them to place within a message on any of the regular boards. An example of this is below. I took a picture from the wallpaper sightings and a couple from Turning.
I could easily write up a simple set of instructions for use. AFAIK this method should take no additional server space. As a bonus, it might be fun just to browse the photos forum! (What I DON'T know is if the photo URL changes when messages are archived - that would blow the deal.)
The only issue I see with this is if people abused it by uploading dozens of pictures then only used a few - this would take more space on the server. However, people seem to be pretty careful with resources in general. (Except for me with my wordy messages!)
Just a thought.
Sample of pictures pulled from elsewhere on the web site. (Assuming the final message displays them like the preview.)
JKJ's favorite fishing hole:
Jerry's photo:
John's big tool:
A well rounded turner has one. Be capped or be square:
A better way *LINK*
>John, I appreciate your thoughtful suggestion. I could start another board easily enough, but I don't think it is the best solution to our photo posting/archiving needs. The best way would be a new messageboard package that will do all these things and also allow individual visitors to maintain their own photo archives on our servers. Until such time as that might happen, I think we need to show people how easy it is to save camera images at a reasonable resolution and file size, which we've tried to do through the FAQs. (I apologize for any FAQs that are outdated. BTW, the FAQ link is in the gray navigation bar at the top of the message index. I thought that was enough, but if people can't find the link, we need to make it more obvious.)
An even better interim measure would be to see if I can get a site license or some kind of third-party link for one of the simpler photo utilities out there, such as PixResizer, that visitors could use without even leaving the message form. I keep hoping that a bright coder will come along and take on some of these projects, as I am quickly out of my depth with dynamic functionalities. If anyone knows of someone who might be of assistance, I would be happy to discuss our needs with them.
Work with me on these things, and in the meantime, I will personally resize pictures for anyone who can't figure out how to use PixResizer or another simple photo utility.
PixResizer Download
Messageboard FAQs link
It's come to my attention that I am in fact blind, guilty as charged. The "Messageboard FAQs" link is in the grey top menu on the message index page, right next to "Spam Patrol". It points to a FAQ more up-do-date than the one I put in the link.
