Delta lathe riser blocks- seeing John's ....
Jamie D
>...mods to a mini Jet reminded me of a similar project I made many years ago. I needed a portable lathe for demos "afield" and wondered why someone didn't produce such riser items for the masses of similar lathes. There would be a big market for all the swing capacity "challanged" lathes of this type, including old metal rebuilds, and seems to me the parts could be easily and economically injection molded from some of the dense plastics available today. I shortened the bed of this old Delta 700 as well, and the tool rest post is a trailer axle spindle from Tractor Supply. The walnut 2 1/2" riser blocks have worked just fine, and the old Reeves drive with a link belt does a satisfactory job for low cost compared to a VFD/new motor for the infrequent use it receives these days.
Re: Delta lathe riser blocks- seeing John's ....
Re: Ooopps, forgot the pic!!
Jamie D
Texian
>Tool rest posts can also be made from the appropriate size (and length) bolt from the hardware store. They do not really need to be cold rolled or hardened steel. Cut off the head and threads, and you have tool post material for cheap.
