Jet riser blocks
>I've been meaning to explore this with my Jet mini so here are some photos of the riser I made this morning. It took about an hour to make all the parts. I glued up some baltic birch plywood and then cut it to the proper length and width for the headstock and tailstock. Then I cut dado's in both sides. One is for the tailstock to fit and the other is for a piece of wood that will fit in the lathe bed gap. I glued the wood into the riser block.
Then I drilled a 1" hole for the tailstock locking bolt. I have a lathe and mill and could have just made a new longer locking bolt to replace the original but decided instead to make a short connecting bolt because this is something you could make with a drill press, 10mm metric tap.hacksaw and a file. I drilled a 5/8" piece of steel rod and filed flats on 2 sides. Then hacksaw'd it off tapped it for the 10mm. I threaded a nut and the new connecting bolt onto the original tailstock lock. Then I cut a short piece off a 10mm bolt and inserted this thread onto the connecting bolt. Reassemble everything and I'm done.
I'll drill and glue up the riser for the headstock on another day. When done I'll have a 12" jet mini.
