band saw blade
ponch
>Got a new grizzly band saw this week. It came with a blade that will not cut butter. Doing some research, I figured I needed a hook blade to cut logs. Any ideas of how many teeth per inch (TPI) I need?
band saw blade
ponch
Re: band saw blade
wilbur
>Generally, the thicker the thing you are trying to cut on a bandsaw, the coarser the teeth should be. 3 TPI is a typical blade used for cutting logs down.
You might want to contact Suffolk Machinery, and just tell them what it is you are trying to cut, and they will give you a good recommendation as to the type of blade you should use.
Re: band saw blade
Scott Hurley in N. VA
>I use either a 3 or 4 tpi hook blade, 3/8" for most of my work. Check out woodcraftbands.com - they will make any type you want for a very reasonable price. Also, HighlandWoodworking.com has very reasonable prices, and a specialty blade for woodturners - the teeth have a wide set for slicing through green wood.
Scott
Re: band saw blade
>What size bandsaw and what horsepower motor? I usually used a 3 tpi on a 14" saw for green wood because I couldn't find anything coarser. I used a 4 TPI in a pinch but it didn't work as well.
I've been using a wide 1.5" TPI Lenox on an 18" saw and it is wonderful for green wood. The blade looks similar to the one used on my sawmill. If you buy a large blade for a smaller saw make sure you can tension it properly or it will be a waste of time. Most 14" saws will barely tension a 5/8" blade. I can barely tension the large blade enough on the 18" saw according to my tension meter.
I've bought some blades from Iturra Design (866-883-8064) that worked well - a Lenox and a Bladerunner 3/4 TPI variable. The Bladerunner is the same as the Woodslicer.
They also carry Starrett bimetal blades which I'm about to try. A mesquite log section really dulls any carbon steel blade quickly.
Re: band saw blade
Brian Hahn in SW Wisconsin
>A hook tooth is good for ripping logs, but can be a little too eager when cross-cutting or sawing bowl blanks. A skip tooth is better for cross-cutting green wood.
I've got a Delta 14" with a riser block and I use the coarsest blade I can find. For ripping green wood I use a 5/8" 3 tpi blade with half the teeth removed. The cut ain't pretty, but that blade loves to eat wood. For cutting round blanks I use a 1/4" or 3/8" blade with 4 tpi to get a smaller cutting radius.
Re: band saw blade
>I can vouch for Brian's method of removing every other tooth. When processing a bunch of dogwood a few months ago I removed every other tooth of a carbon steel blade. I snapped each tooth off with pliers then smoothed the jagged break with a small grinding wheel. I'll bet the grinding is not needed. This makes an amazing difference in the ease of cutting dense green wood.
BTW, Brian, I can't tell you how much money I've saved using the technique you wrote about to sharpen blades. I sharpen every coarse blade at least once, usually twice. The other day I dulled a brand new 142" 3TPI blade by cutting up one 14"x8" mesquite log section. Five or six rip cuts and the blade was useless. A quick sharpening with and it was good as new. (For those who might think this would take forever, I timed it - 8 minutes with a Dremel to save $30!)
Thanks *LINK*
>John, I'm glad the information was useful.
The article that John is referring to was posted on the AAW forum a couple of years ago.
Sharpening Band Saw Blades
sharpening bandsaw blades *LINK*
>Brian,
After your initial inspiration, besides thinning the teeth I tried a number of techniques for the sharpening and ended up refining another method which just hits the top of each tooth. I remember you said you only sharpen the gullets for certain woods. Sharpening the top only is much faster. (A 142" blade with 3TPI has 426 teeth!) Sharpening the top, of course, leaves the original gullet alone except for reducing it's size a tiny bit.
Suggested by Steven Russell in a 2003 message here: "Touch the flat part of the wheel lightly to the top of each tooth, and gently arc the wheel down along the top of each tooth ... you can elect to sharpen the entire tooth [including gullets], instead of just the top portion only [but] sharpening only the top portion of each tooth is faster than sharpening the entire tooth, which requires two separate operations."
Two things I do different from that - one, I don't bother with the arc he suggests but just touch grinding disk leaving a flat bevel on the front of each tooth. This takes maybe a 1/4 second per tooth. I tried the arc method and couldn't tell any difference except the tooth looked prettier.
Second, Steven recommended to change the angle of the grinding disk for left, right, and center set teeth, but I prefer your method and sharpen straight across and I can't tell any difference. And it's a LOT faster!.
Another thing I do different from your method is sharpen with the blade on the saw. This is sloppier but faster and saves me from making a vise. :) I raise the upper guide to expose about a foot of blade, then touch each tooth from top to bottom. Of course I won't get the angles as consistent as you do in the vise, but it only takes a few seconds to do all the exposed teeth before I pull the blade down to expose more teeth. Since I don't care about the smoothness of the cut, I don't worry to much about getting the teeth the same height (which would keep more uniform set), something done carefully by 'jointing' with a file as the first step in quality sharpening a hand saw. I usually sharpen a band saw blade twice before the set is reduced enough to make it not worth the effort.
BTW, I use the side of thin disks that Dremel sells as metal cutoff wheels. They last practically forever in this application. There is almost no pressure so a wheel is unlikely to shatter, but for anyone trying this don't forget the safety glasses.
(And as I read in a chainsaw manual recently, always turn off the saw before sharpening. Zounds!!!!)
sharpen as quickly as changing blade
robert davis
>and a lot less trouble. ialso sharpen a blade several times
Re: sharpening bandsaw blades
>You're right, a blade doesn't need to be pretty to do a good job ripping!
I tried jointing the teeth on a band saw blade once. Sharpening afterwards was a real PITA.
Ron Lynch
>Turn off the chain saw! Why didn't I think of that?
