Re: Finishing with Brushing Lacquer
Greg Haugen
>What are you trying to finish? Large or small items?
I've used a thinned brushing lacquer as a "sealing" coat and then either applied a paste wax over it or repeated the process to slightly build up the finish. I've gone this on boxes and small items mostly. It's a Ray Key technique. With the lathe stopped, I dip a cloth in the thinned lacquer and wipe it on the piece. I give it 30 seconds to a minute to soak in. I wipe off the "standing" excess first, and then turn the lathe on to rub in/burnish the finish. The heat basically speeds the curing process. I've done on the inside of boxes and no "smell" was detected within an hour or so. It's a production method of sealing and finishing a piece. I also use it on ornaments, more of a sealing coat and then they're sprayed once assembled. Since the wood is sealed, the parts can be handled during assmebly without the fear of transferring fingerprints onto the bare wood plus it shortens the finishing time since it's sealed already.
As far as it being used as a finish that is padded, brushed? It's rather difficult to do so on a round vertical object. That technqiue would be best used for flat work, shelving, cabinets, etc. It can be used as I described as a sealer/primer coat, and I have built it up by repeating the thinned lacquer process and wiping it off then burnishing it.
Hope that helps,
Greg H.
