>Recently, I've started trying to turn small bowls that require no sanding. The other night I almost achieved perfection, with one area that had a minor amount of tearout that could have been removed with 220 grit in one or two swipes.
It's a challenge to turn something that goes straight from the lathe to finishing. I'll probably remount it and give it a quick sanding "just because", but as a "user quality bowl", it doesn't need it.
>I did some goblets once with no sandpaper just to see if I could smooth with cabinet scrapers only, inside and out, cup and stem. I used cedar for even more fun. Worked great! (but finish sanding was quicker) I often turn little things like finger tops from hard exotics with only a little 600 paper. Tools polished on the Tormek make a big difference here. But bigger things like bowls give me far more opportunities to add unevenness, regardless of the tool. :)
Another test was do some turning entirely, from roughing to finish, with Hunter tools. I think I'll always need at least some fine sandpaper or scrapers to get out the tiny ridges - my hands are not that steady.
But I'm too lazy to set many challenges.
I'm not sure what you mean by "user quality bowl" - one meant to be used for salad rather than display?
>Seems kind of crazy to me to sand a salad bowl to 2000 grit wet paper, but then again, what do I know? If I intend to eat from it, I go 220-320 max, and I might use a coat of spray lacquer or a quick wipe down with mineral oil, but that's it.
Aftre that, it's popcorn butter and finger oil finish.
>Steve After seeing Stewart Batty turn a winged vessel with one side sanded to 400 grit and the other side turned with just his 45 degree bowl gouge. You could not tell the difference. I decided I wanted to be able to do that. I've been working on it. I often get to the 220 stage and sometimes finer. Mostly it's taught me more about tool control. Not having to sand was not the goal. Learning how to cut that well was and still is.
My main goal is to figure out why I'm turning. Do I want to say something with my turnings. Do I want to be famous. Do I simply enjoy all the learning or is it the teaching that I like. I don't know yet but I'm sure having a heck of a journey.
>Good question Steve. My goal is to turn something I'm not capable of; something beyond my abilities. I like pushing the envelope. I try to create pieces that appear to be moving even though they're sitting still....If I succeed, I'll try to make the next piece even better. Even though my pieces don't usually need lots of sanding, I don't mind the sanding process at all.
>Having been at this for just I few years, I have learned much but still feel much of what I do is based on work I have seen. I am still trying to find my personal style so that when someone sees my work they will have a good idea of its creator.
Being an enginner with a logical, linear thought process, I have easily learned many of the techncial aspects of turning, I am now working on learning the finer points of artistic style of pleasing shapes and forms.
>Seriously, when you get to a certain point in the journey, catches are mostly eliminated (unless I'm doing something really quickly or talking to someone).
To your point John, that's kind of what I meant. Aside from not being a fan of sanding, I get personal satisfaction in knowing that my skills are improving.
