Photo Question
Photo Question
Photo Question
Sean Troy
>Hey all, I'm using a EZ-Cube photo tent with the cheapie Halogen lights on the sides and incandesent on top for taking pics of my turnings. With a white background, are you using a + or - for the white scale setting on the camera? My camera is a Canon A-590. Thanks for any info, Sean
Re: Photo Question
Re: Photo Question
DickL in Tampa
>Hey Sean,
Look in your camera manual for instructions on setting a custom white balance for your camera. It involves using a white or gray card with the lights you intend to use with your tent and will set it dead on. Works like a charm on my wife's Canon A95 (and my Nikon).
Re: Photo Question
Re:The white background is highly.....
Jamie D
>....reflective, and the camera meter will render it gray(underexposed) without a +1 or more manual exposure correction.
Re: Photo Question
Re: Photo Question
>Jamie's correct. +1 or +1.5 should do the trick. If everything is white be sure and clean the lens to reduce the flare and if it happens to have a lens hood use that.
Re: Photo Question
Re: Photo Question
Sean Troy
>thank you all for the help, sean
Re: Photo Question
bob elliott
>When you say exposure correction, would that be the same as exposure compensation (as in Nikon-speak)?
Re: Photo Question
Re: Is same same Nikonese!
Jamie D
Re: Photo Question
white scale setting?
>Sean,
One thing is not clear in this picture, at least to me. The term "white scale setting" is not a typical camera term AFAIK.
Are you asking about "white balance", the setting to prevent a color shift caused by your specific lights? If so, the Tungstun setting will probably work OK. A better way is to use the custom white balance feature if your camera has it - on most cameras you simply aim the camera at a white sheet of paper held where the subject would be and ask the camera to adjust for your particular lights. This will help prevent an overall color shift - something gray should come out gray.
Or do you mean exposure adjustment, needed to keep the camera from being tricked by the bright background underexposing the subject? (I suspect so, since you mentioned the "+ or -".) If so, you can indeed bump the exposure compensation, mostly by trial and error, and check the result. Another way is use the manual exposure mode on the camera: set a reasonable shutter speed, then aim the camera at a gray card placed at the subject location and adjust the aperture for the proper exposure. In a pinch, you can meter the exposure to the palm of your hand. Sometimes it works great to zoom in on the subject itself (if it's not too dark or light) and set the exposure before zooming back out to frame the shot. Any way you do it, direct metering is generally more precise and consistent with less guessing. However, some cameras make this a painful process and it's easier to just push the button to change the compensation with trial and error.
But there is one thing to keep in mind when using auto exposure with exposure compensation: depending on the exposure mode your camera uses (center weighted, spot, etc), the exposure compensation you use with one object in the light cube may not be the same as with a different object or even with the same object placed differently in the frame. For example, a larger bowl might require a different exposure compensation number than a smaller weed pot since the meter will see more of the bright white background with the smaller object.
You might check your manual - some cameras have a backlit/bright background exposure mode that may do a pretty good job in this situation.
Also note that even with all possible care it may still require quite a bit of trial and error to get a good shot of a jet-black ebony bowl or a pure white holly vase!
Re: Photo Question
Re: white scale setting?
Sean Troy
>I did mean balance, sorry for the confusion.
