Home Made tools
Home Made tools
Dick Hines
Home Made tools
Dick Hines
>I spent this afternoon turning the handles on the new hollowing tools I am making for turning minis. I am doing a demo in Feb at my club so I thought I might as well make a set of tools.
I used 3/16" round drill rod and a compression fitting for the ferrules. I will try to post a picture in to next day or so.
Am going to try them out tomorrow to see if I wasted my time or not.
Re: Home Made tools
Re: Home Made tools
>I'm not sure what your hollowing but I think 3/16 would be too small. I have 1/4" , 5/16 and 3/8". The 1/4" ones are good for shallow ornaments but start to chatter with the larger ones. The 5/16 are excellent for those.
Re: Home Made tools
Steven Antonucci
Should work great.
steve antonucci
>3/16" is a little thin though except for the smallest forms. 1/4" is better and much more versatile. I use the 3/16" for 2"-3" pots...
Steve
Re: Home Made tools
Re: Home Made tools
Charlie Drake
>I have been making some small (1/8 & 5/16 inch) turning tools. Straight ones are no problem with HSS round stock but is it possible to bend HSS? I've tried heating with acetylene torch and it just breaks. Or is this the reason folks use things like allen wrench for bent tools-you just can't bend HSS?
Re: Home Made tools
Re: Home Made tools
>I've never tried bending HSS so I can't answer your question. If your heating it to red hot and it won't bend without breaking then I guess it can't be bent. For small hollowing tools I find drill rod to be excellent. I heat treat the tip and it seems to hold an edge for a pretty good while.
Re: Home Made tools
Ed Moore -- pitch in here....
Chuck Engstrom
>Seems to me Ed Moore showed the Chesapeake Woodturners some HSS tools he bent on a Harbor Freight bender back when he lived in Annapolis. Maybe he could lend his wisdom here.
Best to all --
Chuck Engstrom
Re: Home Made tools
Re: Should work great.
Carole Valentine
>You put a 3" pot in the "smallest forms" range??? I would include 1 1/2" or less in that category. Dick makes some lovely tiny hollow forms in that range and 3/16 would be fine. I have used that as well as 1/8".
Dick, don't forget to post pics. Have you guys had your Studio Tour yet? Ours is coming up Thanksgiving weekend.
Re: Home Made tools
Dick Hines
Re: Ed Moore -- pitch in here....
Dick Hines
>First. To bend HHS you need Mapp gas. The stuff in the blue tank will not get hot enough.
Second. I will use the tools on hollow forms in the 3' or less size. Like some of the ones Carole does.
Third. Yes Carole we had our studio tour in Oct. Lots of lookers but not many buyers. Hope yours does well.
Here are the picture of the tools. 3/16" round HHS bar, poplar handles, and compression nuts for ferrules. Brass turnes nicely with a scraper.
The handles are 8" long
Re: Home Made tools
Re: Home Made tools Allen wrench
GalenV
>Being new to turning I don't know all the negatives to making tools but I just followed a friends idea on the Allen wrenches. I made this tool with a 1/4" Allen wrench and projects 4 1/2" on a 7 1/2" handle. I'm just learning how much I can project tool over the rest and how much cut I can make. Seems to stay sharp.
I still have a set of double ended boring bars left from a metal lathe I had and thinking of using them but have not came up with a small set screw type holder to allow using straight or angles end of bar.
Have any experienced turners used steel lathe boring bars for small truning tools and how did you handle?
Re: Home Made tools
Steven Antonucci
Smallest definition (mine at least)
steve antonucci
>anything 3"x3" or smaller, usually cut through a 3/8" hole or smaller (small holes are almost impossible to clear chips!)
Medium - bigger than small, up to 5"x8", give or take (hole is about 5/8" +/-)
Large- well, bigger than medium, to date up to about 14" deep and up to 12" wide. Undercutting gets hairy here. 1" hole
Small tools vibrate way too much for my tastes on anything too much bigger than I've described. Most cases, I use smaller tools on bigger forms until they can no longer reach, then switch to bigger tools (gets tiring hand holding a 7# bar that's 4' long...)
Steve
Re: Home Made tools
Steven Antonucci
If you steel wool the ends. they clean up nicely
steve antonucci
>I've also used spent sandpaper (600grit) to remove the bluing.
FYI- I use my Thompson detail gouge to turn brass. Works nicely, no chatter like I used to get with a scraper.
Steve
Re: Home Made tools
Re: Home Made tools
nick
>Try a different kind of steel. HSS is not necessary. I've never used it and have made a pretty much complete set of turning tools: gouges, skews, scrapers, etc. I use 52100 ball bearing steel.
Re: Home Made tools
Re: Home Made tools
nick
>Why do put ferrules on the handles? I've made many turning tools and I never bother with ferrules. Sometimes the tool breaks but the handles never do.
Re: Home Made tools
Chuck, my apologies ...
Ed Moore in SW Virginia
>I didn't spot this thread until just now and did not respond in a timely manner.
I have a bender from Harbor Freight and I did bring some 1/4" tools to the Chesapeake meeting. I bent the steel rods and then drilled them and put HSS tips in them using CA glue. I made handles with set screws to hold the tools. In retrospect, I made the tools a little too long, but they still work whenever I make a globe type ornament. The trick is to not let the tools get hot so that they melt the CA glue. Silver solder would be nicer.
Lord willin' and the creek don't rise, I will be teaching an ornament class at John C Campbell Folk School in November of 2009 and I am considering making tools for that class to use and possibly purchase. C.A. Savoy of Capital Area Woodturners used to make these tools and then he went to 5/16" stock. Maybe he still makes them in that size.
Ed
Re: Home Made tools
Dick Hines
Re: Home Made tools
Dick Hines
>I learned how to make the tools from Myron Curtis and he always pot ferrules on his handles. It gives the tool a nice touch and they are easy to do.
Re: Home Made tools
Re: Nick- the ferrules reduce the .....
Jamie D
>... possibility of the tool steel splitting the handle at the point where the joint is weakest because it is thin.
Re: Home Made tools
>Yes, I split one freshly turned handle a few weeks ago since I didn't have any good ferrule material handy and I was too impatient. Drat! I ended up winding steel wire around the end and coating with epoxy. I've since bought enough copper and brass tubing ad fittings to make handles for years.
I'm guessing ferrules would not be necessary if you left the entry end nice and fat and didn't force fit the tool shaft.
Re: Home Made tools
Bob Macgregor
>I ran out of copper pipe fittings last time I made handles and used some pieces of metal electrical conduit pipe; it works fine and gives a different look from the more traditional brass/copper ferrules.
BOB
Re: Home Made tools
Re:To keep the color scheme of my .....
Jamie D
>....ferrules in "harmony" with HSS tool shafts I use aluminum tubing rather than copper or brass. The aluminum is easily worked and doesn't oxidize readily, and best of all it's phrugal!
Re: Home Made tools
Where do you buy the aluminum tubing?
Michael Stafford
Re: Home Made tools
Re:Many hardware stores have aluminum......
Jamie D
>...materials including tube stock, and there are always old nylon web lawn chairs being tossed,etc.
Re: Home Made tools
Re:Many hardware stores have aluminum...... *LINK*
>Home Depot here carries it as well, in the section with steel angle iron and bars. I can't imagine a more expensive place to buy metals but I guess you don't need a lot.
Another source is a fabrication shop. A metal supplier usually only sells uncut stock but a fab shop builds things from steel and aluminum and has bins and piles of scrap offcuts. There is one in Knoxville I visit occasionally. I collect what looks useful to me, put it in a pile, and the guy comes out and guesses at the weight and says $10 or whatever. I'm sure they would give away a few short pieces of aluminum tubing for free if I asked nicely. (I've bought many 20' lengths of square tubing, i-beams and angle iron from them.)
Next time I go I'll check. What size would be best? The tubing they use is generally quite a bit heavier than what is used in lawn chairs.
You can order lengths from places such as the link below (prices are per foot) but the shipping would probably be prohibitive. Anyone in your area build airplanes?
http://www.aircraftspruce.com/catalog/mepages/alum
