Box sanding
Box sanding
Box sanding
DaveG
>I have found it very difficult to sand the bottom in my turned box. Even though it fells smooth I can see scratches. Seems like I can sand allday long and still have scratches. I know if the sand paper is held still scratches will appear but on the bottom of a 1 to 1.5 inch diam box kind of hard to move back and forth.
What am I doing wrong?
Thanks
Re: Box sanding
Re: Box sanding
Carole Valentine
>I power sand with a 1 1/8" disk on a 1" sanding mandrel. you can just move it and tilt it enough to get a good sanding job when you progress through the grits. If it's a little too small for that, I use small pads of foam backed paper folded and gripped with forceps.
Re: Box sanding
Re: Box sanding *LINK*
Fred Holder
>I generally sand the bottom of boxes with a 2" hook and loop disc holder mounted in a Jacobs chuck mounted in the headstock of the lathe and the box held in my hand. The rotating sanding disk is less likely to leave scratches than a piece of hand held sandpaper.
Alternately, I use the same hook and loop disc holder mounted in the chuck on the end of the Guinevere sanding system from King Arthur Tools. It runs at a fairly high speed and does a very nice job of sanding the bottoms of boxes.
More Woodturning Website
Re: Box sanding
Box sanding
Ed Moore in SW Virginia
>Dave,
If I am going to use Shellawax for a box finish I sand by putting a dab of paste wax on the paper when I start. It lubricates and gives a good surface. Run through the grits and stop using wax once you get to 240 or 320. There should still be some wax in the grain from the 240 grit paper, but the wax should not be obvious at 400. Use 600 and then put some Triple E wax on some paper towel and polish with that. Now apply the Shellawax. You should have a very smooth surface.
Ed
Re: Box sanding
Slight hijack - what about Scotchbrite pads?
>I use them as a final sanding step in spindles - would they work for boxes?
Re: Box sanding
Re: Box sanding
>Dave I use a narrow strip in the end of my finger and start at the bottom center and pull the strip out toward the top. So far that's been working best.
Re: Box sanding
Keith Tompkins
Re: Box sanding
keith tompkins
>Dave, Make sure that's not torn grain you're noticing. That is very difficult to get rid of. The fibers of the wood can be torn out, leaving damage far below the surface. The Hunter/Eliminator type tool is good for leaving a good finish that needs very little sanding.
Re: Box sanding
Re: Box sanding
Michael Stafford
>Like Carole I use a small sanding disc and H&L sandpaper to sand the bottom of my boxes. If necessary I will use a 1" holder and cut paper down to 1 1/2" and cut it radially to form a flap sander which does a wonderful job on undercut forms.
When using a sanding disc do not apply a lot of pressure. I can almost guarantee concentric circles in the bottom if you do and they can be terribly hard to remove. Be sure to vacuum out the dust and any loose grit before moving on to the next grit. Also extra pressure means extra heat which can cause heat checks and just as Ed said a little wax is a good idea for lubricating the process.
I also cut discs of various grits of woven abrasive pads which are easily held by the H&L holders. I almost always finish up with those to remove any sanding marks. I also cut them oversized and then create radial slits to make a flap sanding arrangement. I get a fairly good finish in my boxes that way.
Re: Box sanding
Re: Box sanding
Terry Scott
>Hi Dave I use usually wet sand my boxes by mixing in 20% detergent with water ,or oil sand .The slurry build up seems to lose those the scratches.The harder the timber the better finish you get with this method .It also helps overheating the work eliminating heat checks.I place the mix in a bottle that cleaners are supplied in .
Cheers
Re: Box sanding
Re: Box sanding
gary s clarke
>In addition to all of the above, sometimes the only to get a scratch free surface is to end (after power sanding) by hand sanding. just my 2 cents worth.
Re: Box sanding
Re: Box sanding
DaveG
>Thanks all
I probably do apply more preasure than what is needed. I will try a lighter touch on my next box.
Re: Box sanding
Re: Box sanding
nick
>That's what I do, too. Sand with the grain with 320 or 400 grit.
