REAL MILK PAINT
Scratches from buffing
>I have been having problems with what I thought were scratches in my turnings due to sanding or inability to see the sanding scratches. I thought it was my vision, or my lighting, or sanding dust in the scratches that hid them. I think I was wrong. I will find out tonight. I think the problem may be contaminated buffing wheels. I have sanded a bowl to 600 grit followed by 4/0 steel wool and then applied a wipe on varnish. It looked beautiful until I tried to finish it. After the Tripoli buff I had scratches that I could see and I'm absolutely positive they weren't in the wood or finish. I'm going to try and clean the wheel tonight and see. I'll let you know.
Re: Scratches from buffing
Wally Dickerman in Arizona
>John, have you cleaned the Tripoli wheel with heavy grit sandpaper? I've done it with 80 grit followed by applying a piece of wood to the wheel to clear any grit left on the wheel. I once noticed scratches on the wood after doing this.
Wally
Carole Valentine
>That will definitely do it John. I blow my wheels out before I use them and I don't load them up with compound because that attracts grit, etc. I try to keep my wheels in a 2 gallon ziploc bag to keep them from picking up dust, but I am not always good about putting them back in there when I am through using them.
>I thought I would use a saw on edge to clean them and then use the corner of a wood block to further clean them. I don't have a build up of wax at all so it's got to be grit or wood chips embedded. Anyone have a better idea, I'm certainly open. I've sanded this darn bowl 3 times now and don't want to do it anymore.
mpax356
>I use a Beall 3 on 1 on a mini lathe a few feet in front of my PM3520. I always keep the wheels covered with a couple of towls to keep the chips and dust off of them when not in use.
cagey59
>I have tossed all 3 of my 3" bowl buffs in the washing machine, shhhh, didn't tell my wife. Tried to dry them in the dryer but the thumping was too much. Put them in the furnace room for a day. They are almost as good as new now.
>Thanks Ken you gave me a good chuckle.
Ed Heuslein
>John, knife makers wouldn't dream of buffing a blade without first cleaning the wheel with a rake. You can buy rakes at knife making suppliers such as Treeline. You can also use old files (coarse are best), or a myriad of other things - but in my opinion the rakes work best. I have one and use it every time I buff - even on the wax wheel although, like you, it doesn't seem to have any buildup. After raking, I use sissors to cut off the long threads and blow it off with my air hose. - Ed
Have Questions
Texian
>John,
What does the 4/0 after 600 do for the surface? Why not just 800, 1200? Have buffed with the white compound, which increases the gloss a bit and makes the piece feel better in hand. Can you quantify how buffing with tripoli improves the surface? TIA.
Re: Have Questions
>I used the 4/0 simply because I had it. It is finer than 600, probably in the range of 1000 to 1200. I don't know what tripoli is on the grit scale but somewhere above 1200 I think. It works well to take out fine scratches in the finish or orange peel in the finish.
Thanks Ed and Gil.
>I'm going to try to "rake" it with what ever I can find in the shop that might do the job. Then I'll blow it out and trim it. If that doesn't work I have laundry to do and it should fit in nicely with my levi's and shop rags.
I now have an electric skillet and microwave , Iron and stereo in my shop. Now I need a washer and dryer. Pretty soon I'll need a TV and and oven and sure could use the kitchen sink, not to mention a bathroom.
Adrien's SWMBO
>What's your wifes name and phone number...we need to have a chat :-)
Re: Thanks Ed and Gil.
bill Crommett
>John : Just don't displace the lathe with Kitchen Stuff.
A hacksaw blade works nicely.
success
>Thanks for all the tips. I used a drywall saw as a rake to clean the wheels. Then I trimmed the loose fibers. Then I blew them out with the compressor. You could see an awful lot of dust come out when I blew them out. Then I charged them with compound and ran a clean piece of wood through them. I trimmed off any more loose fibers. Then I charged the wheels again buffed the bowl. No scratches. I don't know why I didn't think of that earlier. Sometimes you just get your mind in a rut I guess.
Steel curry comb works too on dressing buffer.
GalenV
John, I use a 40 grit belt to clean
Allen Neighbors
>my buffing wheels - and 125psi stream of air.
You give me pause... I need to be careful about blowing the table of my drill press. My buffing motor is just 3 feet away. I need to make sure that the wheels are in the case before blowing off the dp table. Thanks for the heads up.
I found some small swirls in the bottom of a large bowl I was buffing, and know it wasn't there on the lathe. I decided it's the end of the shaft on my buffing motor arbor. I made some 8 and 9 inch wheels. Maybe that will solve that problem, anyway. I think I was just careless about buffing with the smaller wheels.
Hope you find out what caused your problem.
don lewonczyk
>No wonder your called Cagey, if your wife finds out they might call you something else, hmmmmm, maybe your voice will suddenly have a higher pitch to it? DonL
Brian Hahn in SW Wisconsin
>A bathroom and kitchen sink were high on my priority list when I built my shop.
My shop is 100' from the house, so the plumbing is really nice when it's -20 with a stiff breeze.
Re: Have Questions
Texian
>Thanks John.
