What's wrong with my buffing??
Kimberly Draper
>I bought a Penn State 3-in-1 buffing system. How do I know I have enough wax/compound on the wheels? When I used them, (in the right order) I come away with white stuff on my product. What gives?
Kimberly Draper
Re: What's wrong with my buffing??
Dick Coers
>With most open pore woods, I skip the white diamond compound. Since you are just putting on wax with the last wheel, there is nothing to remove the white compound. It's my opinion that you need very little wax. Too much of that it will just attract hand oils and dirt. If there is any shine, you have enough wax. I know that there will be someone that is more technical about this, but just trying to get the conversation going. On my Christmas ornaments, I have gone to two coats of spray on shellac, then a good hard buffing with the orange, then to the wax. It has a nice shine and the orange is aggresive enough to take out the orange peel from the airesol can spraying.
Kimberly Draper
>Hmmm. I am using it on Ebony. I'm new to working with exotic wood. Maybe I won't need any buffing? Or, maybe I need to stay off the white dimond?
Carole Valentine
>I don't use white diamond on most dark woods. You also don't need much compound at all. My wheels are 4 years old and you don't see any compound buildup at all.
Rick Allen
>Different folks have different experience with buffing. This is my experince.
I avoid the rouge compound on light colored woods and I avoid the white compound on dark colored woods.
There are many woods which can be buffed with both abrasive compounds. Even wood which I normally wouldn't with the white are successful if there is enough build up of finish to fill the pours. Of course that tends to yield a "plastic" looking finish.
I have buffed ebony before with all wheels and the effect was shinny as I was expecting.
Things to look out for:
If a finish hasn't hardened you can "burn" through the cured outer layer of finish and expose a "gummy" layer that the compound can adhere to. The buffing will likely warm the "gummy" finish enough so that the embedded particles of buffing compound won't come out without removing the finish.
Varnish is particularly bad. It drys slowly, even though the outer surface feels dry. Once varnish drys hard it is VERY resistant to buffing.
Shellac is not very heat resistant and can be "burned" through and softened even after it has been fully cured. BTW this is one of the great things about shellac. A shellac finish is fairly easy to "fix".
Lacquer usually buffs well. It takes a good bit of effort to "burn" through and is soft enough to buff well.
Oil finishes tend to be very well suited to buffing as long as you don't have to many coats. But that brings us back to the light wood dark wood issue.
If you think you have to much compound on the wheels then take a piece of rough wood and buff the edges of that wood to remove the extra compound.
>I use fairly high build finishes such as lacquer so I can get away with using the white diamond on dark woods because the pores are partially or completely filled.
If I use an oil finish then I follow what others have said, skip the white on dark woods and skip the Tripoli on light woods. The tripoli is designed to level a finish and if you have done a decent enough job sanding they you won't need the tripoli. My lacquer spraying isn't perfect because of the quality gun I use and the area where I spray so I need the tripoli to level this surface.
I'm with Carol. I've used my wheels for at least 4 years other than being ragged looking you can't see any build up at all on the white and wax and only a light tan color on the tripoli wheel.
Kimberly Draper
>Thanks! I will try everything y'all said and see how it goes.
