Box Elder
Jim Canning
>Someone has offered me some box elder. I have never turned it before is there anything to look out for or to do special to the wood when turning?
Box Elder
Jim Canning
Re: Box Elder
Greg Haugen
>That's a horrible wood to turn, you should send it to me and I'll take care of it for you. :-) Just kidding. It's one of my favorite woods to turn and it's basically a "soft" maple in turning. It's an excellent wood to turn, very forgiving. Enjoy it.
If it has some "red" fungus streaks, it will fade, faster if it's exposed to sunlight. So be mindful of that.
Greg H.
Re: Box Elder
>Can you get any of the root??? The box elder I've had was always kind of soft and turned easily, with mild pink and occasionally darker red streaks. However, someone recently gave me some box elder root dug up from a fairly large tree. The wood is the most spectacular pink and red, leaning a bit towards orange in places. These are not streaks but large masses of color, swirled with the patterns you often see in roots.
If the tree was cut locally, perhaps the root ball is still there for the digging.
Re:Much of Box Elder is without ....
Jamie Donaldson
>...interesting grain patterns or color, and it makes good turning material for value adding carving/texturing subjects. And much of the wood I've turned smelled like it grew over the sceptic tank!
Re: Box Elder
GalenV
>A friend gave me some smaller piece of box elder for my first time with green wood.
It was stringy wet and best when dry use a coat of shellac and
shape tool for last cut.
Pictures are poor and pieces not the best but you may get an idea of wood.
Geesh! How about fresh SHARP tool :-)
GalenV
Re: Box Elder
Carole Valentine
>It's a soft maple. Sharp tools needed, especially if it is dry. The burls can be spectacular, and are good candidates for coloring with transparent dyes and glossy finishes. The red streaks you often see in BE will fade to brown with exposure to sunlight.
Michael Stafford
>Box elder always grows greener over the septic tank....
