22 degree angle ?
22 degree angle ?
22 degree angle ?
>I was looking (OK drooling) over the new Packard catalog and saw an angle measuring gauge called the Woodcut Tri-Gauge. It said it has the angles needed to check gauges and scrapers. it has 55, 35 and 22. Anyone know what the 22 degrees is used for.
Re: 22 degree angle ?
Greg Haugen
>John, the only thing I can think of would be a skew but that's a tool I'd think a gauge wouldn't be necessary. Maybe one side, not the bevel but the shaft of the tool is placed on the gauge and the other side of the bevel is checked? I have no idea. I've also seen some french bedans with some intense angles as well.
Yeah, that doesn't seem to be a common angle.
Not much help, I know.
Greg H.
Brian Hahn in SW Wisconsin
>My best guess is for a skew.
Personally, I don't use any of the angles on that gauge.
Russ Fairfield
>I grind a spindle gouge to something close to 25 degrees. Try it sometime. Wicked, but sweet once you get control of it.
arkie
>Carving tools?
Keith Tompkins
keith tompkins
>Me too Russ. It gives a long bevel to ride on.
Texian
>Also drooling. Dunno about those angles though. I grind my stuff very precisely to "that looks about right" degrees. Seriously doubt that I could feel the difference between 55 and, say, 57 degrees, although some probably can. Aren't hand plane blades ground to 22?
Dennis in Southern Oregon
>Hey, 22 is awfully close to 22.5, which is 1/16 of a circle. I am not a segmented vessel turner, but I would guess that a 22.5 degree angle would be useful there. The "22" may just be an abbreviation for "22.5"
Dennis
Crown Moulding? :o)
Allen Neighbors
Irish Grind ?
Texian
>Recall someone on another forum mentioned 22 degree angle in connection with an irish grind gouge. The way it was stated, I did not understand if he meant a 22 degree included bevel angle (oooow, sharp).
Bob Macgregor
>A wild speculation: any grinds at 68 degrees (90-22) that the gauge would work for?
