Big bandsaw
Big bandsaw
Dick Hines
Big bandsaw
Dick Hines
>I saw a big band saw in a wood workers shop Sunday. When I say big I mean 28" cut with a blade that was 19'6". I asked him if that was right and he said he had one in the basement that was larger. It would resaw up 30". I did not see the hole in the floor that it fell through.
This is the saw for you guys that like turning BIG wood.
Re: Big bandsaw
Re: Big bandsaw
>Hey, I used one like that in 1969 when I worked at the Berea College woodcraft industries. At least they told me it had a 20' long blade - I didn't measure it! I was making little parts from walnut and cherry for some of their marble games.
Have you ever seen the bandsaws used in large sawmills? There's one near here that uses a vertical bandsaw and while I didn't get closer than about 50', the blade appeared to be maybe 10-12" wide and must have been at least 40' long - the thing was huge. It was cutting through 30" logs about as fast as I can push a 4/4 board through my bandsaw. A guy who worked there said there was a person who worked full-time just doing maintenance on the blades. An amazing operation, a debarker feed logs to the main saw, lasers optimized cuts, after each board was cut the cants rode around a carousel with others to continuously feed the saw, boards were automatically flipped to a second line if they needed edging, all scrap was fed by a series of conveyors to a massive chipper, a gang of large circular saws on 2' centers cut boards to length, and about 10 people worked just sorting and stacking boards at the end of the line. A great place to get wood as well - I bought trailer loads of red oak at 15 cents a board foot for barn siding (palette grade) - quality went for $0.30.
Re: Big bandsaw
Dick Hines
Re: Big bandsaw
Dick Hines
>Barbara Gill has a band saw mill. She is one of about 4 people I know that have them. I bet they are safer than the old circular blade mills.
My grand father worked in one fo them. If they hit somethig hard like a spike in the log there were saw teeth flying all over the place.
Re: Big bandsaw
Re: Big bandsaw
Ron in Drums PA
>A friend of mine has a bandsaw mill. He can cut up to 50" wide and the carriage will hold a log 18' long.
The table tops are 40" +/- x 120" +/- x 2.125"
The bottom 3 are wenge and six other are highly figured bubinga
You can see the bandsaw in the background.
Re: Big bandsaw
Re: Big bandsaw
Steve Russell
>Hello Dick,
Several years ago I visited a Pattern Makers workshop... Everything was SUPER sized! Like a 48" bandsaw, two lathes that would turn 8 foot diameter bowls (one was being turned the day I visited), a 20" and a 36" jointer (yes that's the width of the table, not the length), a 36" and a 48" planer and tons of other things that needed a crane to be loaded into the shop. I was like a kid in a candy shop! This guy made patterns for huge electric motor casings, oil field pump housings and similar sized work. He used two woods only, Mahogany and Sugar Pine. Man what a place!
Steve Russell
EWW Studio
The Woodlands, Texas
Re: Big bandsaw
Keith Tompkins
Re: Big bandsaw
keith tompkins
>Hi Dick, I once worked in a cabinet shop that had a bandsaw so big, a circular cutout poured in the floor housed the lower wheel. My current shop has an Oliver strait-O- planer with two 25 HP 440 V 3-phase motors. We ran over 45,000 board feet of oak and maple through it last year.
Re: Big bandsaw
Dick Hines
Re: Big bandsaw
Dick Hines
>This guy is a furniture maker he is not cutting logs. He does tables and chairs.
Re: Big bandsaw
personal band saw mills
>I have a band saw mill as well, for 3 years now, here slicing up a slightly bent and rather small pine log. This little mill will handle up to a 28" diameter log 17' long. However, a log that big is pretty hard for ME to handle, so I usually cut larger logs 10'-12'. A white oak log the maximum size for my mill can weigh almost 5000 lbs!!! Even a green yellow poplar log that big would be over 3000 lbs which is more than my tractor can pickup with the forks.
This thing as been incredibly useful around the farm and a bunch of fun as well. It's a great feeling to go to the saw yard and grab a few boards for a project. I'm sawing now for a new horse barn.
The blades for this mill, BTW, are 1-1/4" wide and over 13' long. It's one of the smaller mills Woodmizer sells. Their bigger saws use a blade just over 15'.
As you suspected, band saw mills are far safer than a circular saw. A circular saw can kick back just like a table saw, but throw a 12 foot long 6x6 at you instead of a small piece. About the worse a band saw mill can do is break a blade but that will just stop in the wood. You are more likely to get hurt dropping a cant hook on your foot.
Re: Big bandsaw
Re: Big bandsaw
Doug Thompson near Cleveland
>Those bandsaws are out there just go to a used machinery dealer, most of the time they are less than $1,000... the problem is moving it to your shop.
