How is a Jet 1220VS (DC motor) Supposed to Sound?
Philip Morris
>Placed an order for a Jet 1220VS on Tuesday of this past week and it was drop shipped to my office on Friday from Jet. (BTW, ordered it from McGivern Hydraulics, Doug Thompson's friend/associate - see the links page on Thompson Lathe Tools. They offer true free shipping and their price is around $20 less than most others. Good people, too.)
Anyway, Unpacked the lathe and started it up. Was floored to find it was sooooo quiet. I believe that it is quiter than my Oneway 1640!
My Question:
Is it normal for the DC motor to make kindof a "tickety-tickety" sound, almost like a sewing machine?
When I manually turn the handwheel in the direction of rotation, you can hear a faint "rrrrrrrm" sound from the motor, similar to the noise a car starter makes when the battery is dead an you try to start it. I ran it with the drive belt disconnected from the spindle pulley and it makes the same noise, so it is definitely the motor.
It's not a terrible sound, nor is it very loud. But it is noticable and I just wanted to make sure it is nothing that needs to be addressed.
Also, as many on the forums have noted, the ON/OFF switches are bad. Mine has already stuck ON once. Think I will resource a replacement locally, rather than having Jet send another bad one.
Re: How is a Jet 1220VS (DC motor) Supposed to Sound?
Lyle Jamieson
Lyle Jamieson
>I have a new 12-20 also and could not believe how quiet it runs. I do not have any clicking sound. I took the control box off the lathe so I can get in to change belt speeds without moving the control box. And replaced the switch. I think the switch gets damaged by slamming the control box against the lathe to get the latch to hold it in place. That slamming cant be good for any of the componants in there. Lyle
Philip Morris
>Lyle,
Thanks for the response.
I wondered about the long term effects of the electrics being banged around. Where did you mount them?
Lyle Jamieson
Move 12-20 controls
Lyle Jamieson
>I took it off the lathe and screwed it to the tabletop. The plastic housing has screw eyelets and I put some washers under it to support/lift it off the table. The electrical cord is short so there is not much room, just enough to get my hand into the pullies. In fact I put it on a slight angle. it looks funny but it is stable and it works fine now.
