short bowl gouge.
short bowl gouge.
short bowl gouge.
>I've been working on my Smith lathe/mill trying to tune it up. It's a lot better than it was but I still have some slop I have to work on. I thought I would try to mill a deeper cut to see how it works. I got some chatter but not bad.
I thought I would try to make a bowl gouge tip. This would let me play with different shape grinds or put Hunter tips or other carbide tips on a short piece of steel to see how they work. I'm going to make a bar to hold these and then fit the bar into my Big Stick handles.
This is 5/8" x 4". I milled a small flat on top so I could use my Wolverine jig. I haven't hardened it yet. I'll fine tune the grind after I do that.
Re: short bowl gouge.
Texian
>Interesting. What kind of steel are you using?
Doug Thompson near Cleveland
>Looks good, if you want some of this steel let me know I'll send some down. You mill the flutes then I'll put it in with the next batch to be heat treated.
>This is Drill Rod I bought from Enco
>Doug I was thinking about that possibility. I have an idea for a tool that might be a little different. If I get it worked out I'll send you a sample.
