thinking about the Crushgrind mechanism
Steven Kubien
>Hi all,
I just picked up my first crushgrind mechanism (the shaftless version) and while I am looking at the instructions and the unit itself, I've come up with a couple of questions....
Do you or your clients fill the mill by removing the grey adjustment wheel and filling from the bottom? If not, why not? and this question leads to....
If one were to fill via the bottom, one would not need to drill a through hole and have a cap. The entire mill would be two pieces with the lower piece turning for grinding and the top for holding the fixed end of the mechanism and holding the pepper/salt. Is there a problem I don't see with doing it this way? I figure that the fewer parts I have to fit together accurately, the better (hey, I'm a turner not a furniture maker!).
Your thoughts?
Thanks,
Steve Kubien
Re: thinking about the Crushgrind mechanism
Peter Hyde
>Hi Steve,
One of the GHWG members Doug Bremner has recently shown some mills at the monthly mmeting show and tell. He has now decided the filling through the bottom is the best way to go.
Here's a link http://www.ghwg.ca/pics/showandtell/100-Show%20n%20Tell%20Sep%2008/index2.html
Thanks Peter
Steven Kubien
>I couldn't see any good reason why that wouldn't work. I'll make some up with the more traditional 'mechanism at the bottom' and work on a pattern for putting it in the top as well, like Doug did.
Thanks!
Steve Kubien
Ajax, Ontario
>Seems like you'd have to be careful not to lose the spring. Also, the grey knob adjusts the clearance and the fineness of grind, so each time it is removed it would have to be readjusted. I think I'd rather fill from the top.
When I made one with the shaftless mechanism I used a 1" O-ring to make the cap fit snugly but still easy to remove.
Steven Kubien
>Thanks John. One of the things I was concerned about was removing the cap repeatedly. I wasn't sure what arrangement to use to allow that, that would wear prematurely or require threading. Your O-ring idea fits the bill.
Cheers,
Steve
