What finish is best for bowls?
Richard R. Steussy
>I've normally used Mahoney's walnut oil on my turned bowls, but lately I've started to use a sealant, then beeswax and buff it. Reason--when I make segmented bowls, I find the walnut oil makes the light-colored segments dark or blotchy. I'm looking for a natural dull finish rather than a shiny "Hong Kong" plastic-bowl look. There's a lot of stuff out there and it would take more time and money than I have to try them all. What's the general thinking on a good finish to use with bowls made for food?
Re: What finish is best for bowls?
Allen Neighbors
>Hi, Richard. For utility bowls, I think a good finish is no finish. I use a lacquer wash on my bowls as a sealer, after I get to the 220-320-400 grits or so, and spin/rub it dry with a piece of tee shirt. Then finish sanding, and then buff with Tripoli, White Diamond, and Carnauba. What sealer penetrates, remains in the wood, but there's not much left on the outside by the time I'm finished with it.
The Lacquer wash (65%Thinner/35%Lacquer {close guess is okay}) is something I've thinned down some from Carole Valentine's 50/50 mix. I just like the penetration I get with it.
They tell me that all finishes you can get now are required to be food safe when they're cured.
Barbara Gill, Remlik VA
>I use a penetrating oil on all of my bowls except the ones I want to remain light (bleached and holly). On the light ones I use a water base poly that soaks in like water. It does not give a poly look to the wood.
