Hut friction polish
Hut friction polish
Hut friction polish
bq in vt
>Anyone ever used the Hut friction polish? Was interested in trying it on some smaller pieces and looking for info. Thanks, as always, in advance.
Re: Hut friction polish
Sean Troy
>I've used it with good results but happen to like Mylands a little better.
keith zimmerman, Normal IL
>I got received some when I bought a complete penturning setup, but found the finish was too soft and wasn't durable for pens. I do, however, use it on finger tops and as the first step on bottlestoppers. I like to follow up with a final buffing of my bottlestoppers with carnuba wax using my Beall wheel.
keithz
mpax356
>I got a bottle that was used when I bought my Jet mini lathe used about 15 months ago and am still using it. I have heard that it has a shelf life of only a year but I am a year past the expiration date and it still works fine. I use it on all of my small turnings like ornaments and lidded boxes. I use it over UBeaut EEE which really works great. I have heard several folks that have used it but prefer the Mylands friction polish which is what I will get when I finally run out.
Walta
>I have used Hut Crystal Coat and it works if you want a fast shine that will not take a lot of abuse. If you check the label you will find this is a shellac based product. Liquid shellac has a short shelf life. There is a best used by date on the back label. Shellac is a great finish but you must understand that it has 2 weaknesses alcohol and water and shellac offers little protection from them.
Walta
mfoster
>I use Hut polish now and again. Like others have stated, this is really a wax based finish and I use it as such. If you read their blurb on it, it is really a mix of carnuba wax (and maybe some bees wax, but I'm not sure) and diatomacious earth. The latter acts as a fine abrasive. I believe that the finish is really meant as a top coat over some other finish. I would venture to guess that a majority of turned objects are finished by:
1) sanding to however fine a grit that you can stand or have patience for
2) apply a finish of whatever ilk (shellac, lacquer, varnish or one of the multiple oils)
3) Buff and wax
Hut combines the buffing compound and wax and I usually use it (as I believe it was intended) with the wood spinning and a soft cloth, although it can also be used on a rag wheel with the object in your hands.
