Dye job
Dye job
Dye job
Bob Edwards
>A friend from Seattle, Matt Kramer brought me some spaulted maple on a resent visit. This piece needed something to bring out the character of the wood so I tried a dye job. It is a good grade of food coloring which gives a brilliant color.
Re: Dye job
Wow!! Beautiful. Looks like an emerald.
Gil Jones__Georgia
Re: Dye job
Very Nice, in fact.....
GalenV
>It looks so good do you care if I try the food color on a small hard maple platter that I made and now it just looks blah? Looks like you probably get one chance to do it right with dye concentration and time allowed to soak in. How fine you took sanding I imagine will make a difference. How did you get it right? What type of finish did you use, as it sure gives the piece a lot of depth to the overall finish.
I'm just learning and the shape intitially looks simple but then the small rim bead is there that just adds a soft break I would not think to do.
Again very nice.
Galen
Re: Dye job
Outstanding
nick
>This is outstanding, IMO. I can't believe it's food color. I've never dyed a piece, partly because the dyes are so expensive but now I think I'll give it a try. Any tips or advice?
Re: Dye job
Re: Outstanding
Bob Edwards
>I appreciate the comments. The pot is about 4� the piece 6� overall. I guess I use food coloring mostly because I�m cheep. There are however some tricks. First I get the coloring from Michael�s in the cake decorating dept. The colors are deeper and more vibrant than the sort you find in most grocery stores. You have to do a through sanding job before you apply the color. I dampen the piece several times and sand so that the color has little grain to raise when applied. I sand lightly with 1200 before applying a mixture of 50-50 Deft and lacquer thinner. This consistency soaks in and gives a good base for the four or five coats of spray Deft. Final sanding is about 2400. I don�t use wax as I find it collects dust and leaves finger prints.
