How about things that should be invented??
Russ Fairfield
>There are a lot of tools that should be invented.
My suggestion is a fully automated adjustable tool-rest. The basic rest can be adjusted manually to any height and can be formed into any length and shape to match any form, inside or out, that we are turning. We will never have to move the banjo once it is locked in place, and the tool overhang will always be the same, regardless of the shape of the wood. The fully automatic version will do all of this for us.
Any other suggestions??
Re: How about things that should be invented??
Randy G
>How about a sensor to control the speed to the approx Correct speed on the lathe, also be able to adjust past the vibration point on pieces, and Auto stop during a catch, or oops event?
Just buy yourself a CNC lathe! :)
Carole Valentine
Wally Dickerman in Arizona
>Turning related.... My shop is quite small and the very loud sounds that comes from my dust system bothers me. Why couldn't some state of the art sound deadening material be used in its construction so that all I hear is a very quiet hum?
Wally
Mike Hunter
Mike Hunter
>How about something that eliminates the chip balls when hollowing.
How about Bose headphones?
Michael Stafford
Paul Zerjay
>How about a motorized tailstock quill advance and reverse
Air
Jim Shaver - Oakville, Ont
>How about a pneumatic tool rest? It would dampen tool vibration and adjust to heights?!?!
take it easy,
Jim
gary s clarke
>automatic sharpening so that a bevel could be anywhere from 2mm to whatever is needed. Put the gouge in , set the machine and bingo all done, nice and sharp in seconds.
memory metal tool rest
>Have you seen memory metal. When you heat it the stuff goes back to it's original shape. I'll be in the future you could have metal that will change shape with an electric charge so you could just push a button on the end and it would change shape.
I like the idea of a motorized quill feed on the tailstock. That would be fun.
I think a device that fits on the headstock to since out of balance pieces and would self adjust a counter weight to compensate.
How about a lazar measuring device that senses where the cutter is and adjusts itself to be perpendicular to the cut. Or better yet a sensing device on the cutter that can tell you how thick the wall is. One of my friends tried magnetic sensors but they weren't sensitive enough. In some cases the on/off sensitivity tolerance was greater than the thickness of the wood, oops.
An automatic chip sucker or ejector.
>Just the thing for boxes (probably hollowforms also).
Steven Antonucci
What, and give up my patent rights? :-)
steve antonucci
>Some things that I'd buy-
1.) A hollowing system that was self evacuating on forms that didn't have big voids
2.) A compressor that only ran once for 1 minute and made no noise no matter how many times you hit the air (to run my system in #1)
3.) Sand paper that wore perfectly with the wood to go through all of the grits without changing paper
4.) A lathe that had some kind of system that sensed the tool in my hand, type of wood I was cutting, and then automatically adjusted to put the toolrest in the right spot.
If I had all of these things, I could probably knock a good ten minutes off of most hollowforms :-)
Steve
Steven Antonucci
You must have hit enter first ;-)
steve antonucci
Re: memory metal tool rest
Steven Kubien
>I will second the sensor-activated counter-balance in the headstock. THAT would be awesome.
Steve
Chip in Plano
>Time machine....so I can turn back the clock to rethink that last cut that before a nasty catch. And so I can fast forward to see what that blank will look like before I turn it.
...and of course for winning the lottery so I can afford this dang hobby...and a lathe for every chuck I own.
Ed Davidson (Colorado Springs)
>I think you're referring to Mr. Peabody and Sherman's Wayback Machine.
A non-baker's dozen
>1) I want an x-ray vision fluoroscopic microwave magic alien technology device that will let me see in REAL TIME inside a closed form or bowl on the lathe, to watch where the tool tip is, to see the exact wall thickness, to see just how far away I am from the bottom. If the darn chips would get out of the way, this could actually be done with internal and external scanning laser sensors and software could construct the actual cross-section on a display monitor. 3D laser scanning technology is highly developed but this would actually only need 2d scanning. The inside might also realistically be scanned either sonically or with microwaves. Piece of cake. :)
The next step would be a head-up display on the inside of the safety glasses, perfectly registered with the real view regardless of head position (via 3d coordinate and orientation detection), the x-ray vision display creating a softly glowing overlay view of the insides.
I'd like this next week, please.
2) A more doable thing that doesn't need any alien technology is the catchless hollowing tool, scraper, or gouge - a smart tool that would sense the rapidly increasing force gradient of a building catch and instantly retract just enough to prevent the deadly catch. You could set it for the desired force and simply jam into wood and the electronics and servos would automatically produce just the right amount of cutting force. This would only cost $500 per tool. An enhancement would automatically rotate and position the tip for optimum cutting. Another enhancement would tie this to a thickness sensor to cease cutting at a given thickness.
3) A new way to do offset turning. Imagine turning a bowl depression near the end of a 12' long table top. Instead of spinning the table top on a huge lathe, the table would be stationary and the lathe tool would spin. The turner would grip a tool handle and make cuts as normal on a virtual piece of wood, however the actual tool tip would be spinning around the cutting axis. The key would be a servo system that would sense the tool movements and control the position of the spinning tool. The system would provide haptic feedback so the turner would actually feel the tool in action just as if using a normal lathe. (This technology is well developed.) Visual feedback of the turning would be on a monitor fed by a camera rotating with the tool bit - the visual effect would be that the wood is rotating and the tool stationary. None of this is new - it's all engineering.
4) I want an UNDO key on the handle of my skew chisel. While I'm asking, I want perfect health, infinite resources, and world peace.
5) An MRI machine built into the headstock that would map cracks and voids and figure deep in the chunk of wood.
6) A belly or chest light. I use lights over, behind, and to the sides of the lathe. I want a light for the only part of the work still in shadow. Perhaps a light bar built into or just below the leading edge of the tool rest would be even better, a row of LEDs would do the trick. Also, a switch which turns out all my area lights and turns on a bright point source light for easier surface flaw examination.
7) Quick release headstock spindle. Push a button or flip a lever. No more struggling to unscrew a nicely snugged chuck. No more tapping through the headstock to release a morse taper drive spur.
8) Several programmable speed presets on a variable speed lathe.
9) Electrostatic dust collection. Charge fine sanding dust so it would be attracted to oppositely charged collection devices positioned near the work. A dust collector built into the front edge of the tool rest might also help.
10) Pneumatic risers on the lathe legs to adjust height easily. Could also provide active vibration cancellation.
11) Electronic super glue. Apply glue and position parts. Aim gun at joint and push red button for instant bond. Aim gun at joint and push green button for instant release. Repeat as needed.
12) Voice activated tool storage. Say "half inch gouge, please" or "my favorite bowl gouge" to retrieve and present tool.
Lazy or what? :)
How about....
Dave Peebles Lyons, Ohio!
>A outboard tool rest with a rubber boot that is sucked to the floor by vacuum. Or a tail stock that is not locked down by a cam lock system, but by vacuum.
Too late, John Nichols had both of these at the AAW symposium in Akron is the mid 90's
He was truly a man ahead of his time. A guy could get an education in what was possible by just talking to John for 15 minutes. He was an amazing guy.
Dave
inventions
Philip Duffy
>How about wheels on a shop vac that will run over the electric chord!
How about a shop vac that has a retraction device for the electric chord!
How about a dust filter for a shop vac that really does collect the dust!
Sorry, - -just my normal rants on shop vacs. Wish I had a real woodworking shop with a big collection system outside the building. Phil
A Do-Over machine
Ron in Drums PA
>A Do-Over machine that eliminates that last cut we wished we didn't make.
Re: A non-baker's dozen
Carole Valentine
>Number 12 would save me a ton of time. I seem to spend as much time looking for things in my shop as I do actually using them!
Oh and BTW...my Nova DVR has programmable speed presets.
Adobe shed?
>Hi Wally,
How about moving it to an honest to God adobe shed?
I think it should work...
Jorge
Re: Something possible and practical?
Russ Fairfield
>I hate mobile bases. Why can't someone make something as simple as a mobile base that will roll across the shop floor without stalling on a piece of debris that is thinner than a dime. All it would take are wheels that are a little larger and a little softer.
Keith Tompkins
keith tompkins
>John, Everything on your list looks dooable except the world peace thing....I'm a bit skeptical on that one.
Nichols Lathe...
>You're right, John was quite a guy. I recently sold my lefty Nichols lathe. It was almost like parting with an old friend. I have. and use John's captive hollowing tool. He came out with it long before others came on the market. I think that Don Derry has taken over and is selling a very similar one.
Wally
