>I have made a general revision to my Finishing Secrets article on Lacquer. It is on my website, and linked below.
The original that is here on Wood Central in Russ's Corner is about 15 years old and in need of revision. The new article has some new information, a different format, some rewrite to eliminate confusion, and I have learned to do a few things better. I will leave it to the reader to determine if it is an improvement.
>Wow, greatly expanded. Very nice. I just skimmed it quickly but will read more carefully later.
One question on content. You mention to:
Avoid ... those that are very oily Cocobolo), until you have some experience with lacquer.
Do you have any suggestions other than to gain experience? What about shellac? Someone asked about lacquer on ebony recently. I've heard elsewhere to undercoat lacquer with shellac. I notice you changed your text a bit concerning shellac over oil finishes:
ORIGINAL: To avoid any potential for adhesion problems, brush on a coat of a 2-pound cut dewaxed shellac...
REVISED: Some finishers will recommend using shellac as a barrier between the oil and the lacquer finishes. If you want to do this, brush on a coat of a 2-pound cut dewaxed shellac.
Is shellac no longer as strongly recommended as an undercoat?
BTW, I noticed the sentence about oily wood above needs a '(' before the word Cocobolo. Are you interested in a list of typos? (I got used to proofreading everything I read for my work before I retired.) I jotted down a list of dozen or so typos in case you want to review them for possible correction.
>Just 2 days ago, I sat down with the retail coordinator of the museum store that has been selling my work. My turnings have been displayed for sale along side of the work of 3 other local turners, and real wood products sell quite well there, particularly during the tourist season.
She told me that she much preferred my work (although it is typically priced higher) because she says, "...your work turns a higher dollar volumn with less shelf space taken, and it continues to sell after the tourists are gone".
My "competition" there does good work. The difference? I call it the "Russ Fairfield Factor", because I have taken years of trial-and-error learning off of the (finishing) curve, and have finally began to see some real progress in my finishes. I still refer to "Russ's Corner" often when I am having trouble with something. I owe it to those "finishing secrets" that has set my work apart from the others.
Thank You, Russ, your's is a great contribution to aspiring turners.
>The short answer is that I have backed off from making a recommendation to use shellac as a barrier coat because saying it is easier than doing it. I know that every book and magazine article that has been written in the past 100 years says to use the shellac as a barrier coat, but that doesn't make it fool-proof. It is an uncertain process and there is no way I can predict success.
The long answer is that there are 2 potential problems, and one probability when using a shellac as a barrier coating over an oil finish. One potential problem is that the shellac may not be as dewaxed as it says on the label. Wax in the shellac puddles on the surface and can cause the same problem for the lacquer as an uncured oil finish, or any other wax on the surface.
The other problem is that the shellac will have to be sanded smooth to remove dust bumps and brush marks before application of a lacquer; and that runs the risk of sanding through the shellac. Shellac is a dust magnet, and brush marks are always a problem with a fast drying finish.
The probability is that the shellac will not adhere to the oil finish if it isn't cured because the solvent (alcohol) in the shellac is not compatible with the oils in the finish under it. In that case, a 2nd adhesion problem is being added to the one that is already there.
The safest way to use shellac as a barrier coat over an oil finish is to wait as long as it takes for the oil to cure. It that case the oil is cured, there is no problem, and the shellac is a waste of time.
I prefer not using the oil finish at all because the lacquer will do just as good a job of accenting the grain, and it does it without the problems of blotching and darker coloring that we often get from an oil finish.
>Thanks for all the information. I have been really struggling to apply a decent lacquer finish without spray equipment. Drips are the main problem. Years ago I worked in a cabinet shop and did all the spray work. That was a piece of cake!
>For some reason, I can never find all of the spelling, grammer errors, and typos until it has been published for a couple weeks. Letting it sit in my computer for the same time isn't the same.
>Here are the notes I made. A second set of eyes always helps.
Also, the titles on the web pages looked a little odd. They are not all that important but the text in the title field is what gets displayed at the top of the browser window and on the tab.
Very nice article. I try to re-read some of these occasionally when I get time.
