Have a question? Ask Woody!
Shop heaters?
Shop heaters?
Shop heaters?
JimCanning
>Ok this is my second winter here in Nebraska and my shop is in the garage, its a one car garage. last winter I got very little time turning becouse it is so cold in it. It does have one vent from the furnace in it but it does not help at all. Last year I tried to cover the garage door with furniture blankets(3 layers)and then I covered them with a heavy blue plastic tarp. It was still 30-45 out there. I have a small propane heater that I got from HD, the kind that drywall men use when hanging drywall in a new house but smaller. It will heat up the garage but I am worried about the fumes that I breath and that get into the house.
Any ideas on how to heat this garage fairly cheap as I am just renting the house for now?
Re: Shop heaters?
Re: Shop heaters?
Sean Troy
>For a garage shop, an oiled filled/sealed electric heater may be just the thing your looking for.
Re: Shop heaters?
Re: Shop heaters?
Pete LaBelle
>Oil filled, radiant, or convection heat from 110 volt electric heaters won't do much for you. Any way you cut it, it is only putting out about 5000 BTU of heat. In an uninsulated garage with many leaks, radiant heat will be your best bet. Warms you & not the air around you. In a large garage with many air leaks, you shouldn't have to worry about any fumes of sorts.
If you are turning in a large garage that doesn't belong to you, Spend a few bucks to build a "room" out of 2x2's and cover with clear heavy gauge plastic. Put a door on it out of the same stuff. This will create a small "room" that will have very few openings, and will do a better job of keeping the heat from your electric heater in. Have done this in the past and it does work well.
Re: Shop heaters?
Re: Shop heaters?
Ace Foster in Port Orchard
>CO detectors are commonly available. One of those should take care of your concern about fumes. Personally, I wouldn't worry; those little heaters are pretty efficient burning.
Re: Shop heaters?
Re: Shop heaters?
Curly Smith
>If you want to spend a bit more money, you can add some foam board insulation and use the plastic as a vapor barrier. The 3/4" stuff at HD (brand name is R-Matte) costs $12 per 4'x8' sheet and has an R value of 5. The film on one side also serves as a radiant barrier. For a fairly small investment you could build a much warmer work area.
Re: Shop heaters?
Re: Shop heaters?
Michael Stadulis in Southern NJ
>Jim,
Don't try to heart the entire garage. Cordon off space..... or a corner of the garage..... around you lathe with plastic sheeting taped together and nailed to the ceiling with some furring strips, and then use an oil filled radiator to warm that small space. Use a small fan to mix the heated and cooler air.
Mike
Re: Shop heaters?
Re: Shop heaters?
Texian
>Many years ago the house where I lived had connections in the one car garage for clothes washer and 220v electric dryer. I never vented the dryer outdoors, and found that in winter it would warm the garage sufficiently for me to work there for short periods of time.
Re: Shop heaters?
Re: Shop heaters?
Lan Brady
>Jim,
The water filter dryer exhaust is a great way to heat the room, but it adds some moisure to the air.
In my garage, I use a heated floor mat. If your feet are warm, you can tolerate a cooler temperature.
Lan
Re: Shop heaters?
Re: Shop heaters?
don lewonczyk
>Lee Vally has a infrared hanging heater that heats anything its directed at and not the air, last I looked it was around $60. That along with a heated floor mat like they sell to keep animals warm will keep your feet warm so for around $100. or less you sound be very comfortable even though your temp in garage maybe 35degs. Now if you have a breeze blowing through your garage you might have a problem.
DonL
Re: Shop heaters?
Propane
Barbara Gill, Remlik VA
>When propane burns water and carbon dioxide are produced. I have an unvented propane heater on the wall of my turning space. The heater has an oxygen sensor that will turn off the unit if the oxygen gets low. This has never happened. I turn on the heater when I get to the shop. It will heat me right out of there if I leave it on high.
Re: Shop heaters?
Re: Propane
JimCanning
>Thanks Barbra, I don't think that you remember me. I used to live in Manassas VA. My wife and I came down to your place maybe 3 years ago and you gave me 3-4 big pcs of oak burl from GA. I still have a couple of small pcs left. My wife still talks about you and your mill. Thanks again! Jim in the corn fields of Nebraska.
Re: Shop heaters?
Re: Propane
>I do remember you and your wife and have wondered how that oak worked for you. Ya'll sure did move to a cold place!
Re: Shop heaters?
Re: Propane
JimCanning
>Yes it was a big move. We came out here to do missinary work on a Indian Reservation. I also do silversmithing so I am trying to get the tribe to give me space for a shop/classroom. I want to teach the teens and adults silversmithing and woodturning. They now have a space for me and are trying to settle on how much it will cast them to just build out the area. Then comes the hard work I will be doing a lot of fund raising and getting donations from the suppliers for the tools and supplies as a outreach to the tribe. It has been a real learning experiance. A whole lot differant the designing and selling kitchens!
Re: Shop heaters?
Dick Hines
Re: Propane
Dick Hines
>I heat my shop with kerosene. I put a new wick in my heater every year and that keeps it burning clean. Only part of the over head in the shop is closed off so I never get any fumes or oil smell.
I also crack the door to let air flow. The is a fan in the back of the shop so with the door cracked I get a fresh air flow.
