More Questions on Jet 1220VS
Philip Morris
>I have called Jet Technical Service, but could not get definitive answers to the following questions, so I thought I would ask the experts.
Jet's literature indicates that the VS model has 3 speed ranges instead of the direct drive's 6. However, the parts diagrams in the online manuals on Jet's website indicate that the direct drive and VS share the same pulleys and belt (i.e., same part numbers).
1. Can someone confirm whether the VS has 3 speeds or 6 speeds?
2. If 3 speeds, is the belt wider than what's used on the direct drive?
Some of Jet's literature (i.e., Protalk brouchure on their website) lists the 1220 VS low speed at 200 rpm. However, all of the mail order websites list it at 270 rpm. The Tech Services guy was positive it is 200. Does anyone know for sure?
Re: More Questions on Jet 1220VS
>The 1220 I played on had a 3 step pulley. I don't think you can see the difference between 200 and 270 rpm so I wouldn't worry about that.
Cyril Griesbach
>I can't comment directly on the Jet 1220 because I haven't seen one yet but my wife's Jet 1014 VS has three pulleys and the speed is variable within the range of each pulley selection.
On the low speed pulley set the range is 500 - 1200
On the Med speed pulley set the range is 1100 - 2600
On the High speed pulley set the range is 1700 - 3900
I can't imagine that the 1214VS is significantly different other than the bigger motor and added swing capacity and length.
