>I have this problem of not boring the inside a side of my ring box where I have to make a jam chuck to fit. Seems like I don't get it straight enough. I have discounted buying a compound,cost and awkardness,but am considering an angle iron rest and making a boring tool with a square shank to rub against the angle side. Anyone comment on such? Thks,pw
>Paul Just use a short ruler. When making boxes, especially threaded ones, it's important to have the lips for the lids parallel to the ways. I simply hold a 6" ruler up and touch the sides. Then I eyeball the ruler compared to the bed. It's very easy to see any angle created. Just remove a hair more wood and check again. It doesn't take much to get it perfectly true and parallel to the bed.
The problem with doing the tool rest thing is you still have to get the tool rest perpendicular to the bed so unless you build a seperate tool rest or jig that mounts to the bed to keep is square you still have the same problem.
>Thks John,I can see I would be trading one problem for another-guess my screw driver boring tool is really the culprit and I should do better here-ha ha. Not much room to get a regular tool when using a mini lathe. Problems,problems,and more. I get the box almost completed and crack it with a jam chuck trying to clean up the bottom part! Hmm,would anybody really notice those jaw marks if I just chuck it up... he he. pw.
>Paul My fine tuning tools for box lips are both screwdrivers. I have one ground for left side scraping and one ground for rightside scaping. I haven't found anything better.
>Hmmm,you must have a better grade of screw driver John... he he. Have a great wk,my turning will have to wait on the weather,its cold in my garage(Louisville,KY). By the way,Do you have something like a Lyle Jamison hollow boring apparatus? pw
>Paul I buy old screwdrivers from the flea mkt. They are better quality steel than most of the new ones, except the carbide tipped ones of course. No more than I use these they don't have to be HSS.
I do have a homemade version of the Lyle Jamieson boring bar. I have actually thought about setting up a rig to do exactly what you were describing early on. That is, being able to bore a perfectly straight hole through a piece.
I think it would be pretty easy to make a guide arm to set between the tool rest and the secondary tool rest. This guide would have 2 pins that the arm of the boring bar would slide against. These would be stops, so you could start hollowing and when it hits these pins it stops. When you finish the hollowing you could place the tool against these pins and drag it up the side so the side would be perfectly parallel to the ways.
I was looking at this as a way to make some long round drawers that go into turnings. The hole for the drawers would be bored this way.
>>...get the box almost completed and crack it with a jam chuck trying to clean up the bottom
If you leave a little "mountain" on the bottom when parting off you can bring up the tailstock to support the piece against a jam chuck that doesn't fit so tight. After cleaning up most of the bottom and reducing the center support to a slender pillar, I pare it off and finish by hand, or occasionally hold the piece against the jam chuck loosely in one hand while cleaning up the very center with a sharp tool. A little tape can help hold the box into place as well.
>Probably if I made ea box with the same inner diameter;ie,use same forstner drill,I would be ok. Appreciate your ans,and yep,using the tailend always helps. I get little odd pcs sometimes, and that causes all the problems,but it gives the most satisfying results when I don't muck it up.. pw
>A machinist could probably make you a rig for perpendicular boring, but it would cost an arm and a leg. I learned the 6 inch ruler at a 3 day workshop with Bonnie Klein, and it works fine. This straight edge is only necessary with the mating surfaces of the lid and box. Getting it perfectly straight on the inside is difficult. My way around that is to make the sides curved. A gentle curve is easier to do, and it looks better.
>Oh, yes, another tip from Bonnie. Get a bunch of locking nuts to match your spindle, for me, 1 inch by 8 tpi (box of 10 here from the borg store was about $35). You don't want the straight nuts because they aren't thick enough, the locking washers stand out far enough that you won't need a spacer between the headstock and the nut. Use a spacer to mount the nut and turn out the plastic locking part (you don't need to remove every single bit of it, just enough so it won't lock on your spindle. I did use a Thompson scraper to touch up the surface so it would mount true on my lathe. Then get some scrap pine and cut into rectangles. Drill center holes, about 1/2 inch deep to match the nuts. Press the nuts in, and I use meduim super glue to seal the nuts in. They will take a day or 2 to dry, and I apply enough glue for it to sink in half way, then come back and fill it in. turn the rectangle down to a circle, and you have a bunch of cheao waste blocks. More efficient than face plate mounting, and chuck mounting of a waste block. You want to use a soft wood (softer then what you are jamming on) for the jam chuck as it will compress a slight bit and is less likely to cause splitting.
>Thanks robo,I usually just glue on blocks to a face plate,but lately,just chucked up a larger block and turned to a jam,don't have to wait for it for glue to dry and I can't really tell any
difference,unless of course,I hit the jaws with my cutter... he he .pw
>Why not do what Cindy Drozda does: grind one of your tools so that it is perfectly square with a sharp edge on the left side near the front. This edge must be perfectly perpendicular to the front edge. Then, when cutting into the box to make the lip, the left side will cut the inside of the lip. AND ... you keep watching the long edge of the tool and keep it parallel to the lathe bed. This method, IMHO, is better than using a ruler because you get it right as you cut -- instead of going back and forth from the ruler to the cut and back again,etc. One thing you will find, though, is that as you sharpen the left side, the tool will begin to look 'L'- shaped. So what?
>>...grind one of your tools so that it is perfectly square with a sharp edge on the left side near the front
If I understand you properly, I've tried that but prefer a scraper ground as in the picture 1/2 way down the page in the link. It's ground at an angle so sharpening it doesn't change the shape. Sorby sells one like this for tool buyers. I haven't encountered a problem keeping the side parallel to the axis.
>Paul, a number of things have been suggested and they all will work but I have to ask a question. What are you currently using to hollow the box?
I use a gouge for the main part of the work but if I want to get nice straight sides I use a square scraper ground with some relief on the left side. If you use a square scraper you have to have the tool rest positioned so that the cutting edge is well above center so that the lower left side of the tool does not contact the side of the box and push the cutting edge toward the center. You almost have to have the bottom of the tool at the center height of the box to prevent a problem. Quite frequently I have seen people with the tool rest too low and as they push in the tool it gets pushed to the right as the cut progresses resulting in sides that are not parallel.
You may be having another problem but a sharp square scraper pushed straight in removing small amounts of wood will result in straight parallel surfaces. It also helps to have the spindle speed up. When you push the tool in you should be very deliberate and make one continuous cut not pausing on moving the tool handle side to side as you make the cut. I also relieve the end of the tool so the left corner is ever so slightly longer than the right corner. If the tool is straight across you will more than likely catch when you hit bottom and if you are not careful have a terrific catch.
>I have a box scraper something like that one , too. I use it inside the box to go down the side of the box and don't worry much about having the inside of the box parallel to the lathe bed. What I was getting at in my post was a tool just to cut 1/4 inch or so inside lip of either the lid or the box bottom in a way that helps keep this cut exactly parallel to the lathe bed. It has to be parallel for proper jam fitting, which was the issue in the original post. Again, I first saw it used by cindy Drozda when she does her finial boxes. In a sense, box making is an exercise in jam fitting.
