Have a question? Ask Woody!
Now what? Help!
Now what? Help!
Now what? Help!
Don in Northern Arizona
>I bought some pieces of big leaf maple burl from a traveling wood vendor this week. This spalted piece was being roughed out when I noticed a shiny spot as the wood spun. Turned off the lathe and oh, oh. I'm sure I'll find the rest of the nail if I chuck it and hollow out the inside. Firewood? Try to dig it out? I really paid too much for the wood to burn it. My easy rougher just thought it was grey wood and polished it, experiencing no damage. Nice tool.
Don
Re: Now what? Help!
Re: Now what? Help!
robo hippy
>I am a bit surprised that there isn't more metal staining from it. For me, I use a cheap bench chisel, chop some wood out from around it, and get some vice grips, grab ahold, and pull it out. Fill with super glue and saw dust, and finish it out. Always makes an interesting story. If you are going to core, you could find more of the nail/nails inside.
robo hippy
Re: Now what? Help!
Re: Now what? Help!
Brian Hahn in SW Wisconsin
>The best option is to dig it out like robo hippy suggested.
An alternative is to leave it in. I've done that when I couldn't remove the nail without destroying the piece. HSS turning tools will handle mild steel like that nail. Hardened (cut) nails are a different story, but a hardened nail would have taken a chunk out of your easy-rougher.
Re: Now what? Help!
It's not a bug, it's a feature.
adrien
Re: Now what? Help!
Re: Now what? Help!
Ron in Drums PA
>Is it lead from a bullet? How does your gouge look?
Re: Now what? Help!
Re: Now what? Help!
Carole Valentine
>That was my thought, Ron. There is no staining and it looks like the gouge cut it pretty cleanly. It's easy to tell if it's lead...you can scrape a bit of that off with a knife blade whereas you can't do that to steel. If it is lead, Don, just keep on turning!
Re: Now what? Help!
Re: Now what? Help!
>You can also test with a magnet. If it's not attracted from the appearance in the photo it's probably lead or aluminum, either of which can be turned in place.
Re: Now what? Help!
Looks like it's lead
>Carol,
I could peel a little off with my pocket knife. Guess I will go ahead and try coring it.
Thanks,
Don
Re: Now what? Help!
Thanks Reed and Brian
Re: Now what? Help!
Re: Now what? Help!
eliot d------WebKitFormBoundaryu+MBDi+0MX0Pf5O9---
>I certainly wouldn't throw the bowl away. Depending on how you feel about celebrating the problem, you could dig it out and fill the space in with something like Inlace, the idea being to set up an interesting contrast instead of trying to disguise the void.
