Questions About Jet 1220vs
Philip Morris
>Recently, I sold a larger lathe and am in the process of downsizing.
I am considering the Jet 1220, but trying to decide between the base model and the variable speed model. Accordingly, I have the following questions.
1. Does the DC motor on the variable speed lose much torque at the 270 rpm setting? Does the motor begin to overheat at this low setting?
2. My other lathe had VFD and I was a little turned off by the complexity/cost of the black box controller (I know they are supposed to be super reliable). Is the motor/controller on the variable speed 1220 some proprietary design of Jet�s that will cost more than the lathe if it ever has to be serviced?
3. I assume that it is as quiet as a non-variable speed direct pulley driven lathe?
Thanks,
Re: Questions About Jet 1220vs
>I don't own one but have turned on one for a short while. It is quiet. The motor does lose power at the slower speeds but it has a 3/4 horse motor instead of the 1/2 that the older jet mini has so it's still got a decent amount of torque. It's definitely not the same power the bigger lathes have so you do have to take lighter cuts but I thought it was pretty decent.
I didn't run it at low speeds long enough to tell if the motor overheated.
The motor is the expensive part of the equation when it comes to replacement. I have not priced the parts on the 12/20 but on the 10/14 jet the motor is half the cost of the lathe and the controller about 1/4 the cost. In all my years of working with Jet mini's I have not seen a bad controller. A few motors and lots of switches but no controllers.
If you buy the non variable speed motor you will probably find that you won't have to change speeds quite as often as with the older machines because the motor is larger and of course there's less chance of failure and less expensive if it does fail.
robo hippy
>I have only had mine a short while. I did try the McNaughton micro coring tool on it. I put it in the slowest speed range, and it had plenty of power to core with, but the chips wouldn't eject well. It cored fine in the middle speed range at higher speeds. So, it does a fair job of keeping the torque. In fact, I was impressed with the amount of torque that it has. I would recomend the variable speed. I am mostly a bowl turner, and have heard that this is not a good lathe for turning a lot of bowls on. The bearings are too close together, and will wear out faster. I am using it mostly for boxes and smaller turnings. My Robust is just a bit too much for those. My switch did go out at the store, they replaced it, and that one went out as well. I posted about that here and on another forum, and responce was that this happens all the time, and just replace it with a toggle switch from the local hardware store. When my switch failed, it was in the on position. I have it plugged into a multi strip, and use that for the off/on problem.
robo hippy
Lyle Jamieson
Lyle Jamieson
>Hi Phillip, I just got a 12-20 to take to symposiums and demonstrate my Hollowing and laser systems. I got the variable speed because I want control of the vibration issue. The torque can be compensated for by keeping the belts set so the variable speed is working near full speed. It is when you have the belt set at fast speeds and the variable speed set for low speeds that you loose power and torque. This is true for any lathe not just minis. Lyle
