Lacquer and Ebony
Sean Troy
>Hey all, can Lacquer be applied to Ebony with good results if the Ebony is cleaned with Acetone? Thanks, Sean
Lacquer and Ebony
Sean Troy
Re: Lacquer and Ebony *LINK*
mfoster
>I completed a segmented piece not too long ago made from ebony and holly. I did not want any amber color added to the piece so decided not to use Waterlox (my finish of choice) or varnish. I went ahead with lacquer without really giving it a thought. It took the finish beautifully with nothing done to prime the surface short of sanding. No acetone or any other solvent first. I will sometimes use solvent when gluing oily wood, but usually not for finishing it. Understand that my piece was true ebony, not any of the look alikes such a blackwood. Blackwood feels much oilier to me than ebony, and may not take the lacquer as well. Give it a try on a small cut off if you have one, or on a hidden area if you're really worried. The nice thing about lacquer is that it dries so quickly that you should know pretty fast whether it will work or not. A small area would be easy to clean up if it didn't (with lacquer thinner) and subsequent coats would make the area blend right in since each coat partially dissolves and melds with the previous coats. The piece I was speaking about is posted on the front page of my site. Good luck.
Breezy Hill Turning
Sean Troy
>Thanks Michael, the wood is Ebony and I'm using some really nice white Holly also that I don't want yellowed.
>I personally haven't lacquered ebony but I use a shellac-based friction polish all the time on small turnings of ebony, cocobolo, and other exotics. If you have any problem with the lacquer or simply want to insure success, you can use shellac under the ebony lacquer. Shellac will stick to nearly everything and nearly any other finish will go on top of shellac. Also, make sure the wood is dry.
You can read more about shellac under lacquer in Russ's Corner on this web site. An excerpt, discussing the importance of using dewaxed shellac:
To avoid any potential for adhesion problems, brush on a coat of a 2-pound cut dewaxed shellac. It is best to mix your own shellac because any wax in the shellac could cause problems with the lacquer. Commercial pre-mixed shellac can be dewaxed by pouring it into a quart Mason jar, letting it sit for several days until the heavier waxes have settled to the bottom, and then decanting the clear shellac into another container, leaving the waxes behind. Sand the shellac lightly with 600-grit or the same grit that used last for finishing the wood. Buff lightly with steel wool and proceed.
Sean Troy
>Hi John, I'm using the Ebony with some Holly and don't want the amber coloring. Thanks for the info though, Sean
