Re: Thompson gouge for back hollowing?
Fog Tanner
>It is hard to describe the grind, it is not symetrical at all. The left hand side of the gouge is ground in what would be a normal fingernail profile, except it is around a 60 degree bevel instead of 40. From the center, the right hand wing is group back an inch or more such that it gives clearence when cutting, there is no way for it to contact the wood. Looking from above, it is a shallow curve along the right side from the center of the tip and the left looks normal. The way it is ground allows you to use the right hand side as a shear scraper on the outside. Craft Supply used to have a picture of it in their catalog.
To use it, you position the tool on center. If you put a ruler accross the flute it would be pointing about 5 degrees past vertical towards 1:00. You can then push the gouge in much like a spade pit and drill your depth hole. I put a mark on the gouge for the target depth.
Once you have the hole "drilled", you start with the gouge at center and the flute at a 45 degree angle (around 10:00). Using your left hand as a pivot point you move the edge through an arc from center towards the edge. The depth of the cut is dictated by the shaprness of the tool, wood, how much out of the chuck/over the rest and how much of a hurry you are in. You will be "told" when you are taking too much. You repeat until you get to the bottom of your depth hole and then clean up with a scraper.
After posting earlier, I wound up with a piece of wood in on of my Vicmarc/Escoulen chuck and decided to hollow it using my 3/8" Key gouge. Worked as described above, the piece didn't give a hint of coming out of the cup chuck. It produces much less lateral load than when using the backhollowing technique - at least in my case. I tend to get in a hurry when back hollowing since the wood comes out so quickly. It is worth learning the Ray Key method for those times where you need a more delicate hollowing method.
I think you will like the Thompson gouge for back hollowing. The flute depth works better than my Henry Taylor that had always been my goto gouge for that.
Fog
