Another Buffing Question
Sean Troy
>Hey all, I just finished oiling three hollow forms with Mahoney's Walnut Oil and have them inside the house to dry. It's been so long sense I've used my Beall buffing system I forgot how long it takes for the oil to dry enough to start buffing the forms. Any info would be appreciated. Thanks, Sean
Re: Another Buffing Question
Carole Valentine
>"Til it's dry." (Sorry, couldn't resist!) LOL
I have found that that particular oil takes a long time to dry (weeks or more) but then I have also been told that I may have had a bad batch of oil.
It all depends on so many factors: temp, humidity, type of wood and how much oil it absorbed...
I figure that it is dry when really fine sandpaper, say 600 grit or higher, makes dust instead of gumming up.
Sean Troy
>Thanks. That makes good sense. With the temps going to go back down tommorrow and the heater on at night, I'm thinking the humidity level will be low enough to help dry the oil a little faster. Hopefully anyway.
Bill Howatt
>Within reason, the longer you can wait the better. Ideally you don't just want the finish dry to the touch but to have properly cured. If it isn't ready the finish will not deveop a nice uniform shine.
Bill
Sean Troy
>I've made that mistake before of rushing the buffing and what a mess it does make.
Ric Taylor
Ric Taylor
>Sean,
I use Waterlox, generally three coats. I put on the first coat, wipe it as dry as I can after letting it set for a few minutes, and buff it the next day. I immediately apply the second coat, wipe it dry the same way, then buff again the next day. Then the third coat goes on, wiped dry again, and final-buffed a day later. This results in a permanent smooth gloss finish.
Occasionally (not often) I'll buff again a week or so later, but that is just because I'm fussy.
This is in a very high humidity area (Southeast Texas Gulf coast).
Ric
