Re:No problem, but.....
Jesper, Denmark
>The epoxy will leave what is called an amine blush after curing. This needs to be removed with a wet rag and just hot water before you can paint anything else over the resin, otherwise it will not adhere.
The amine is very water soluble, so is easily removed with water.
You also need to realize that the epoxy is sensitive to UV light, so the varnish or laquer over it should have some UV inhibitors in it. Shellac would not have these properties, so if the object is in sunlight, the epoxy will eventually break down.
