Stupid bowl buffing question
wilbur
>If I was to get a Beall system, do I need the bowl buffs to do the inside of a bowl, or will the wheels work on the inside as well?
Re: Stupid bowl buffing question
Dick Hines
Dick Hines
>You don't need the bowl buffs if your bowls are large enough that the 8" wheels will fit into the bowl.
Rick Allen
>Yes you need the bowl buffs also.
Use of the wheels on the inside of a bowl is likely to result in the bowl being ripped from you hands and mashed against some hard sharp edge. This makes the bowl a reminder not to use the wheels on the inside of a bowl instead of the museum piece piece you had in your grasp an instant earlier.
For large and shallow bowls the wheels can be used effectively and safely. But wait until you have destroyed a bowl or two with the buffing wheels before you try to buff out something you prize like a large shallow bowl.
Always keep the spinning buffing wheel away from any leading edge that you are buffing. There is no force you can provide which will prevent a bowl from being removed from your hands if the angle of attack is wrong.
It is truly amazing how fast the bowl is taken away from you. In less than the blink of an eye the bowl is transported from you hands to across your shop hitting anything and everything which might inflict damage along the way. The nature of the operation tends to keep you from being one of the objects which comes into contact with the flying bowl. Still, the bowl could take a weird bounce and attack you. Naturally at this point a lot of the energy in the bowl has been used up in making the bowl more of a series of flying shards of bowl looking for soft flesh to rip open.
All this being said, hundreds if not thousands of objects are buffed each day without any damage, yielding spectacular finishes.
Note to self
Thad
>Dear Self,
Find contentment in an unbuffed finish.
Sincerely,
Self Preservation
Barry Elder
>I did not see in Rick's comments that after the piece has been ripped from your hands and is flying through the air, it usually bounces more than once if it didn't break apart on initial impact! To help prevent rip-offs, use a light touch when buffing. (This is the voice of experience!)
>And it doesn't have to be a bowl to be grabbed and smashed. The buffing wheel is quite capable of hurling an ornament, goblet, or nearly anything else if you start daydreaming and let your guard down.
Bruce McElhaney, Spring Lake, Michigan
>I only use the bowl buffs on small bowls. I don't find them very useful on larger bowls. To me bowl buffing is an excercise in mindfulnessI also use latex gloves when buffing
keith zimmerman, Normal IL
>I just ordered and will soon receive some 4" Beall wheels from Craft Supplies. I hope they will be useful on the inside of my more open bowls. They will still require a light touch so the wheel can do it's intended job with our ripping it out of my hand and creating some new, unintended ornamentation.
keithz
Cyril Griesbach
>I use only the bowl buffs in both sizes and have had no problems with bowl sizes large or small. And....yes....I've lose one or two.
Brian Hahn in SW Wisconsin
>As others have already said, the wheels only work on the insides of large bowls.
I use 6" and 4" buffing wheels from the hardware store to buff the insides of smaller bowls. (I have the Beall bowl buffs but haven't needed them yet...)
Re: Catch 'em!
Ron McKinley
>After losing a few to the buffing wheels I parked a small folding chair under the wheel and added a box of rags to catch the errant bowls. That has saved about 10 pieces so far..........Ron
Carole Valentine
>I dislike those bowl buffs even though I am forced to use them sometimes. They are so darned hard. I don't know why they can't make them softer.
>I have some thick 4" buffs that I think I bought from Craft Supplies. I will have to look. I've had them for a long time. That is all I use. My 8" wheels just sit there. I don't buff at high speed, maybe 1200 to 1500 rpm. I do turn the speed up for the wax step because I feel it helps melt the wax but you could just rotate the piece slower so the friction has a chance to melt the wax.
I can't remember the last time I lost something. I think it's a combination of slow speed, always removing the turning from the wheel when rotating my hand positions, and what I call buffing down hill, that is running from the center out toward an edge or on round pieces from the center down.
Rick Allen
>You have the goblet buffs not the bowl buffs. The bowl buffs are soft and floppy like the wheels.
Another way to catch them
>I use a plastic trash can filled with shavings and a cardboard deflector/back stop.
This tip and picture appeared in Spring 2008 issue of American Woodturner.
Carole Valentine
>Well the package, from Woodcraft, was labeled "Bowl buffs". They are the 4" ones and there is nothing floppy about them, though they are a tad softer than the 2" or 3" ones which are like rocks. I purchased them 4 years ago so maybe they have redesigned them?
What Am I Doing That's Different?...
Wally Dickerman in Arizona
>I've used my Beall system quite a lot and I can't recall even coming close to losing a piece. I've tried to determine what others are doing that causes them to have flying bowls. Understand, I'm not complaining.
Most of the time I attach my buffing wheels to a 1750 motor, so the buffs are turning fairly fast. I always hold the piece against the buffing wheel well below center. I use a fairly light touch but not always. I seldom use the carnuba wax.
Have I just been lucky?
Wally
The light touch I think is key!
Stephen Mushinski
