Stupid question about sand paper
Ray Carson - Lawrenceville, NJ
>Okay, there's "sand paper" and then there's "sand paper". There's flint, (not found commonly) garnet, emery, aluminium oxide, silicon carbide, alumina-zirconia, chromium oxide, etc.
I here of the turners here at WC "sanding through" 400, 600, 800, and even higher grits to achieve the ultimate smooth finish. And the turned pieces ARE beautiful.
I can find sand paper at the big orange and big blue box stores. I even buy it at my local hardware store on occasion and I usually use garnet paper for most cabinet work sanding up to 220. The problem is I can't find garnet paper in 400, 600 and 800 grits. So what are all of you using?
Question:
What type of sanding media do you use for turning (most of the time) and where do you find grits in the 400, 600, 800 range? Is this the charcoal looking stuff used for metal working? Does the black grit get embedded in your turnings and effect finishes? Where do you buy the grits posted here at WC?
Okay that was more than one stupid question. :-)
Thanks in advance,
Ray
