Thanks to John Lucas for his Hunter tool video
Dinyar Chavda
>John, I decided to start a new thread, as the original one is old, and new additions to an old thread tend to get lost.
I have watched your video repeatedly, and the jaggies and pixellating do not bother me in the least bit. Sure I'd like it to be better, but, for me, these videos are for transmitting information, and your video does an excellent job of it.
I have had the Hunter tools for a while now, and, for some reason, just have not been able to get the hang of them---this is not a reflection on the tool itself, but on my lack of ability. I haven't been able to find someone who uses this tool so I can go see him/her, and figure out what I'm doing wrong.
However, after watching your video several times (I hope you don't mind but I copied it onto my hard drive as my DSL connection is not very fast), I am beginning to get the tool to work (most of the time). I think that watching you adjust the bevel and rotate the tool to get it to start cutting was a very useful hint, as was one of your lines that you let the tool cut at its own speed, and don't force it.
If I have one suggestion, it is with regard to the early part of the video, where you talk about the bevel. It would be instructive for me if you pointed out whether the bevel is just the little sliver at the edge, or the entire back of the tool.
Given your background, I'm sure that you are concerned about the visual qualitites of the video. However, as a member of the intended audience, I am very willing to accept the current quality, given the amount of information, and would encourage you to give us more.
Thanks again for doing this, and I hope that you come out with more videos on this tool, particularly using a constrained system like Jamieson's or the Monster for hollowing forms like the ones below.
D.
Re: Thanks to John Lucas for his Hunter tool video
>Thanks Dinyar. I do plan on doing more instructional videos especially with the Hunter tools. The bevel of the tool depends on which tool you have of the Hunter series. The #4 and #3 have enough metal underneath the cutter for function as the bevel. I have made a tool where I removed this material and it still cuts cleanly you just have a very short bevel. On one of the tools Mike sent me to play with the metal underneath stuck out a little and it made it hard to start the cut so I filed it flush with the bottom of the tool.
On the #4 tool I have rounded the bottom steel a little bit more than it came. This makes it easier to start a cut in the center of a box if you didn't predrill a hole. It still works well the way it is I'm just sort of picky about some things.
