New Machine for Nested Bowls ? ? ?
Barry Turner
>At this year's TACA (Tennessee Arts & Crafts Association) Show in Nashville, TN, there was a booth that had several fascinating matching sets of nested bowls. They (the sets of bowls) all obviously came from the same blank. Walls were about 1/2" thick.
What's the big deal? Some of the nested bowls were round, others were oval in shape. All of the bowls were fairly shallow in profile. I don't think we have figured out how to turn oval-shaped, nested bowls yet, have we? The bowls were very uniform in size and shape.
How'd they do that? Is there some kind of special machine that saws these bowls out somehow? I can't remember the name of the turner or where he was from. I had seen him there before. Does anyone know what I am talking about? Thanks.
Re: New Machine for Nested Bowls ? ? ?
Garrett in Victoria
>The oval bowls probably were wet round ones that just dried oval.
Cheers, Garrett
Ken
>Don't know about that,but the best that I have seen were turned by Mike mahoney.I mean he turns those suckers about 1/8th thick with the kel McNaughton coring tool.
Brian Simmons, Heflin, AL
>I saw a DIY show once on a turner in Hawaii that had an oval lathe. The blank actually followed the oval shape and I see no reason why a coring system wouldn't work. I believe there is also an add on lathe chuck for ovals available but the price is high.
Re: Chuck for turning oval bowls
Donna Banfield
>That would be a Vicmarc chuck, and you're right. It is pretty pricey, around $2500 US dollars about a year ago. Who knows what the cost would be today.
robo hippy
>I can think of only 2 ways to get nested oval bowls. Turn green to final thickness, and let them dry and warp, which is the way I do them. The warping will be similar on the nested bowls, but not the same on each one, and some times can vary a lot. The other way would be with the Vicmarl oval turning attachment for a lathe. This would be difficult because the cutter has to be on dead center, and with the thickness (as in cutting height) of the blades, it may not work anyway. If it did, the bowls would have an identical shape. I did see one photo of a Vicmark articulated turning system with a coring blade on it. I asked them about it, and they said it was being developed.
robo hippy
Ron in Drums PA
>Are you sure they where oval?
I've turned natural edged bowls and have been asked how I turn oval bowls, when if fact they where really round.
Re: New Machine for Nested Bowls ? ? ? *LINK*
Brent English
>Commercial production of nested bowls for household use has been going on for 100+ years. Some companies are still in the business - see link -www.bowlmill.com. Pictures aren't very good of the bowl mill, but basically a coring system. They are all cut green which will give an oval shape as they dry. To do distinct ovals, you can use an attachment like Vicmarc sells. These aren't new either, and the mechanism is derived from those developed to turn oval picture frames - been done for about 200 years. There is still an antique mill somewhere around that makes these too, but I couldn't find the link anywhere. Everything old is new again !
bowl mill
Barry Turner
>I think you have it! A bowl mill. It's just that I didn't expect to find mass-produced, machine-cut bowls from a bowl mill at a crafts fair along with individually hand-turned bowls.
I still don't know how they did the oval bowls though. From the looks of them they were machined that way. Thanks.
I don't know if it's antique or not, but the machinery at the Granville Bowl Mill is pretty old. I think there is a similar mill in Holland, Michigan. Maybe that's the one you are thinking of.
Parker
>I have the VOD (Vicmarc Oval Device) and have been using it for about a year. I don't see any way one could core bowls using this. It is a fscinating piece of equipment and you really have to re-think how you turn a bowl.
