>I have both sizes of the Eliminator, used the small one so much I need to turn the cutter. It has a star set screw, I went to Home Depot and Lowes, they don't sell them separate, I have to buy a whole set ($25+/-) which I do not want to do because I'll never use any except the one. What else can I do? Can I throw away the star and get a regular set screw?
I encountered a similar problem. Seems the carbide cutter stayed sharp for so long that I had forgotten that an allen wrench with the correct star head came with the tool! I had "put it away" so as to not lose it. If you have two eliminators, you just might have two of the little tools you need.
Do you mean a set screw with a torx socket? And are you looking for a set screw or the driver?
I'm not familiar with the Eliminator, but you can usually replace any set screw with any other if the threads are the same and the length is close. Places that deal with machines and tools usually have boxes with individual set screws, especially the larger sizes - our local hardware store, the farmer's co-op, Northern Tool, auto parts store, etc. Just be sure the thread matches - i.e., saw vs metric, etc. You will have to use a different driver, a hex key instead of the torx. You may have to special order the smaller sizes, especially if metric.
When buying set screws or replacement machine screws of any type I try to find a nut that fits and take it with me to the store.
Or do you mean you need to find a DRIVER to fit the set screw you have? Mike Hunter sells handy little torx drivers for his carbide tips. But a good set of torx drivers is handy to have around - many things use this head these days. Most sold in the tool and automotive places may be too big, but I once bought a wonderful set of mini-tools from Sears that includes tiny torx drivers - came in a nice zippered case and has jeweler's size flat and phillips drivers as well as small needle-nose pliers, wire cutter, etc.
BTW, there is a nice illustration of various driver types in the link.
My True Value hardware store sells one of those multi tip screw driver handles (you know the kind where there is a reversable shaft that each end holds a reversable tip, 4 sizes in all) with Torx tips raher than screw driver tips. If I recall it was about $8.00 and has four sizes. I use it often in the shop and in the car. You may need to check to see if you need metric.
I don't believe you can simply switch set screws with a 'standard' machine screw. The screws provided with carbide inserts are specially machined on their shank to fit the carbide insert snugly (think of them as mini-Morse tapers). Carbide is quite brittle, and if a 'standard' set screw (like a similarly sized hex cap screw) is used in place of the carbide insert screw, there is the possibility that you can crack the insert through tightening, or crack it in use if there is some play in the shank of the screw as it mates with the insert's hole. This is why a single 'correct' insert screw to match a specific carbide insert can cost several dollars - they are sized to match the hole ('taper') of the specific insert.
You can likely get a correctly-sized TORX wrench (like an Allen key) of a specific Torx number at a machine parts/tools store. Big Box stores likely will have you buy a whole set of wrenches. I have seen individual Torx screwdrivers offered at Sears. You obviously would need to know the size of the tool needed to fit the insert screw head; I would take the Eliminator tool with me wherever I shopped for the wrench to be sure of a good fit. BTW - places selling turning supplies like Packard and Craft Supplies sell replacement Torx wrenches individually.
Don't make the mistake of substituting a 'standard' screw for a special insert screw to save a few bucks on tools and risk breaking a an insert costing $20 or more.
>Hunter tool has to have the right slope on the head, in order to fully support the cutter, or it will break. I suppose the Eliminator is the same. These little carbide cutters are easy to break. I know it sounds weird after using one so long, but it's true. They are very brittle, and must have contact with the shank of the screw all along the little bevel in the hole in the cutter.
>Years ago I bought a small kit of tools intended to accommodate all the screws, hex heads, etc found in general-use computers and there's a double-ended Torx-type item in that. One end fits the Hunter I have, the swan-neck version. Maybe a Radio Shack or Best Buy would have some, or your neighborhood computer geek.
With the carbide cutters in use I suggest you move it very frequently. You can not remember or tell where it is sharp or dull. Moving it randomly every hour or so of use will mean when you get to the end of its life it will be dull 360 degrees. This will get you maximum life to it.
Second suggestion is to take a fine pin, I use a safety pin so I have something to hang onto, and clean the torx screw socket out and blow it clean before you put the torx wrench in it. They are easily stripped. lyle
>Ruth go to this web site www.mcmaster.com under where is says find product top left corner---type in page 2796 this give you a page with all kinds of torx wrenchs that can be purchased individually.
>I have the Eliminator with the 3/8" cutter. The screw you need is a TS-3.5-9M1 insert Torx screw and uses a 08 metric, T-15 Torx Key. The key can be purchased individually from Wholesale Tools. If you will e-mail me with your address, I'll send you a screw if that is what you need.
>Mike Hunter has wrenches for all his tools so I am sure he sells wrenches separately. He in in the hospital right now getting his knee replaced. He will be home in a couple days, if you dont find one sooner.
