>I am looking for a high quality 13/16 fostner bit for boring kaleidoscope blanks. I have one I got from Rockler, but it is dulling quickly, after only a dozen or so 2 1/4" deep holes in endgrain of exotics. I am drilling at 380 rpm, +/-, without extreme pressure, but I can already tell the bit is dulling. For boring just a couple, the bit I have would be okay, but I am looking at a couple of dozen in the next two weeks. (Partial gloat...I made just 6 for a craft show today to see if they would sell, and was pleasantly surprised to sell all 6 in the first 2 hours of the show, with the last lady asking if I had more!)
I don't mind paying a bit more for a bit that will last, even carbide if that is a good cost/benefit . What brand and source would you recommend?
>There was a recent thread about Forstner bits and Russ Fairfield posted about an American Co. that manufactured excellent bits but I have lost the bookmark.
I have used FAMAG bits before, a little pricey but excellent when I was making pepper grinders.
http://www.woodcraft.com/family.aspx?FamilyID=778
Maybe Russ will see this and post again, hope this helps.
>The key to any cutting edge is being able to sharpen the edge.
Sharpening a fostner bit is fairly straight forward. The key is to sharpen (hone) the surface which has the longest flat.
In the picture hone the green surface. Avoid the red surface.
Hone the green surface with a fine diamond hone. Please note that you may need to hone with coarser hones the first time to prep that surface.
How often should you hone? Given that you are having such quick dulling I would hone after every use. Naturally honing works best if done frequently. No more than 4 or 5 passes should be needed once the surface has been prepared for honing.
You might also wish to consider a ship auger for drilling the holes. The ship auger would also need to be sharpened (honed) on a regular bases.
>There is definitely a difference in Forstner bits. I've made a lot of peppermills and gone through a lot of bits. Forstner bits from Europe and USA are superior, IMO. They are also truer in size and runout. I use both Bormax and Convalco bits and can highly recommend both. Bormax bits are very sharp and cut a very smooth hole. Convalco bits have a beefier stem with less runout and vibration, and cut a flatter bottom hole due to a smaller spur. Convalco bit are also easier for me to sharpen. I have used Freud carbide bits, while they keep their edge well, they are not as sharp or smooth.
>One point that should be mentioned, is that Convalco bits are available in sizes from 1/4" to 3" in 1/16" steps. Most other Forstner bits have a more limited size range. I found this out when looking for a 1-1/16" bit needed for peppermills. I do have a 1- 1/16" Bormax bit that is of very high qulaity, and goes through wood like butter.
