Question About Jet 1236 Lathe
Philip Morris
>I recently acquired a used Jet 1236 lathe and have a question about noise when turning between centers.
Without tailstock pressure (i.e., hollowing or finish turning a bowl), it runs pretty quiet. The low speed is a little noisy, but nothing objectionable. When applying pressure from the tailstock, it is noticably louder.
I was wondering if this is an indication of bad bearings, a characteristic of the Reeves drive, or a characteristic of a cheaper lathe. The spindle turns easily and smoothly. There is no discernable notchiness or slop in the spindle bearings. Headstock and tailstock also seem to line up fine.
Thanks
Re: Question About Jet 1236 Lathe
Barry Elder
>Have been using a 1236 for about 4 years and have not had any noise problems as you describe. Perhaps the headstock and tail stock are out of alignment. I bought one of the tools for re-aligning the head and tail stocks after rotating the headstock. It's well worth the money.
GalenV
>Only familiar with older Reeves drives used on water treatment equipment. On them noise could come from them at lower speeds if pulley splines were worn and backlash of pulley halves more noticable. Other areas is noise from when pulley run at one speed and not run through ranges and the shafts would get a groove cut. This was more evident by harder to move between speed changes. The tail stock could be putting more load on the pulleys so backlash from worn pulleys more evident. Probably tells you to only change speeds during running and maybe last owner forced when not. Wonder if you manual has anything about lubrication of the pulley shafts or shift linkage and if done.
Again may not match as used on the lathe but just thoughts since only you can tell by hearing the noise. Sometime you can feel a corresponding vibration and how smooth the unit turns.
Dennis Yoder
>I have heard what might be the same noise on both of my lathes when the lock on the tailstock was not tightened. When I tightened the lock the noise when away. Worth a try. Dennis Y
Philip Morris
>I think I found the problem.
The root cause seems to be a worn live center tip, which was later reground by PO such that it was not aligned with the spur drive center (BTW, this is a different live center than I used to align the headstock and tailstock previously).
I mounted the tip in the spigot jaws of my chuck and used a file to re-true. Everything is much quieter now.
Thanks to all who offered their insights.
Eric Knutsen
>I also acquired a used Jet 1236 VS that had some noise issues. I replaced the drive belt and that seemed to solve the problem. However... a word of advice: Be VERY careful when tightening the tailstock more than you should. Many videos and articles you might read/watch tell you to occasionally tighten the tailstock as you progress further into your work "just to keep things snug". Here is the problem: Jet used a softer metal in the tailstock ram. As you tighten the tailstock, the male threads will progressively bore our the female threads in the ram. Granted the part is cheap but you'll be out of commission until it arrives. Happy turning!
