THE WOODRAT IS BACK!
How do I mount this for hollowing?
Steven Kubien
>Hey there,
Obviously, from the pictures, I started this burly-ball of willow between centres. I would like to make it more sphere-like and hollow it out. I'm just not sure how.
Do I turn a tenon on one end, knowing the ends are mostly bark and void? Turning a tenon would involve losing a LOT of overall size.
Do I rotate 90 degrees so that there is good wood, re-turn it so it is spherical and then put a tenon in the good wood?
Should I lock the spindle, grab a large forstner bit and drill a recess into the good wood and use my jaws in expanding mode?
Let me know what you think.
Thanks,
Steve Kubien
Re: How do I mount this for hollowing?
Would pictures help?
Steven Kubien
picture #2
Steven Kubien
Re: Would pictures help?
Don at Central Illinois
>Man, I am really intersted to see what some of our experts come up with. I thought of a glue block but don't see how that would work. Vacuum chuck, too much bark/voids. As Arte Johnson said in Laugh In, "Veeerrryyy interesting."
Re: picture #2
Sean Troy
>Looking at picture #2,there are two good areas to mount from, 1:00 and 7:00 . You could turn a foot either place for a chuck mount and hollow from the opposite side. You wouldn't need to remove much to get it back to the desired round shape and it would make an exceptional hollow form with voids. Jam chuck it when your finished hollowing and remove the foot.
Greg Haugen
>Steve, I wouldn't recommend making a tenon on anything but "good" wood. Making a tenon on bark and voids you're asking for an accident to happen. If you don't want to "lose" too much, I'd rotate it 90. When you do, don't worry about the shape. Get a good tenon first, then shape it. If you rotate it, shape it, and then put a tenon on it you'll lose the shape you liked and had. For hollow forms I also like what I call a "stepped tenon". The bottom section is what the chuck grips, then the top section is sacrificial, it allows you to eye the form's line down further but still allows for enough wood for support during hollowing. When the form is reversed it the step is turned away. This method also allows for all of the wood to be used, including the "tenon wood," if needed.
Hope that helps...
Steven Antonucci
Ditto
steve antonucci
>Never get a tenon on the two spots you have currently mounted it. Rotate 90 degrees and forget "round" unless you want a smaller form.
Steve
P.S Nice thing is that you won't have any trouble clearing shavings that way...
Mike Brazeau
>Hi Steve - looks like a good candidate for a natural edge bowl with the top at the tailstock end. Don't know what the headstock end looks like. I am not a fan of expanding jaws on fresh wood, expecially if you want to hollow. I turn a recessed tennon and use compression grip. My thoughts.
Mike
Norm Smith
>Steve, I would flatten a bottom where the drive spur is and install a face plate with 1,1/4 screws and turn a natchural edge vase or hollow form.
Norm
Keith Tompkins
Re: picture #2
keith tompkins
>Steve, If you want to preserve the shape, I would mount a scrap piece on a faceplate, then turn a "dish" in the face that conforms to the form you are working on. Glue the form into the dish, using the tailstock for clamping force. Reverse turn when hollowed to remove the glue block.
make a really big wooden jam chuck
>Or better, one turned a bit on the inside to fit the largest diameter of the outside, cut slots axially to make flexible wood "fingers", tighten with a big hose clamp around the outside. I've made several of these to hold pieces I couldn't hold any other way.
Steven Kubien
>Hi Greg,
I know what you mean by putting a tenon only in good wood. What I meant was cutting away the bark/void stuff to get to good wood, which would lose a lot of overall size.
I am having a bit of trouble with what you are saying about the tenon other wise. Have you got a before/after picture to help me wrap my head around? Maybe I am just dense.
Thanks,
Steve
Steven Kubien
>Thanks for the help everyone. What about rotating it to true it up and then using a big doughtnut chuck?
Still not sure what I will do but at least the brain is working. Thanks!
Steve
Lyle Jamieson
Lyle Jamieson
>I love doing burls with voids and using a void to hollow through so that there is no apparent hollowing hole. In my opinion you already took too much off the foot. I would have left as big a flat spot as possible at the foot, once I estabilish the axis, and make a slight concave tenon for a glue block. A chuck is no way to do hollow forms. Glue blocks of faceplates with screws would reduce vibtation tendencies. Chucks fail because they are grabbing a sponge, the wood fails.
Round is hard to do but striking if you nail it. I have done many of these without a bottom...reverse turn the foot away and set it on a separate wooden ring. If it is truely round it will sit in a variety of positions, very dynamic. Lyle
