clearing shavings from holllow forms
clay rose
>what do people use to clear the dust out of enclosed forms. vacuums, can of compressed air? what works best in your opinions? what are some options
clay rose
Re: clearing shavings from holllow forms
Ric Taylor
>Clay,
There are a variety of ways. Many who have a compressor set up in their shop use compressed air. I suppose canned compressed air would work, but that could get expensive after awhile.
I don't have a compressor, so I use a soda straw and just blow it out. Be sure to use the type that bends in the middle so that you can stand off to the side, or the dust and shavings will hit you in the face. That's not a pretty picture.
Ric
Don at Central Illinois
>I have a compressor with a small nozzle and just blow them out. Quick and easy.
Greg Haugen
>Clay,
The soda straw/small piece of plastic hose works well, just make sure you "inhale" before the straw is in your mouth and in the vessel. It will bring a new meaning to "adding fiber to your diet".
I have a compressor with a nozzle I use to blow them out.
I've also seen people take some small copper tubing, bend one end of it and flatten it out into a "rake" shape to scoop/pull the shavings out. This is handy for face grain hollowing since that results more in to "shavings" and not dust. Sometimes a little more than just "air" is required to clear that out.
Hope that helps,
Greg H.
evolution of hollowing
steve antonucci
>finger -->wire tool--> straw --> compressor
after your fingers give out and you get tired of digging them out with a tool, you'll know that air is the way to go. The first time you forget to inhale before putting the tube/straw in your mouth, you'll buy a compressor. DAMHIKT
Steve
who knows that maple wood doesn't taste much like pancake syrup...
>>"adding fiber to your diet"...
...or to your lungs.
I use a small air compressor with a nozzle with a slender 4" tube that fits well inside the piece.
BTW, try supplying a constant stream of compressed air in the hole behind a forstner bit when drilling a deep hole, such as for a pepper grinder. This not only helps keep the chips from building up but cools the bit. It doesn't have to be full blast.
Wally Dickerman in Arizona
>I got tired of blowing shavings and dust around when clearing chips from the inside of a HF.
I use a Shopvac and suck the chips out. I made a wooden plug and use a piece of plastic hose that goes inside a 1 inch or larger opening. The Shopvac is noisy but so is my compressor.
Wally
Do you have any issues with airflow?
steve antonucci
>I could never get my shopvac to work because of airflow. If the opening is the same size as the hose, I would imagine that the same issue would occur?
How big does the hole need to be to get chips out? Does it only work when you have end grain dust or can you pull noodles out too?
I am also tired of compressor noise...
Steve
Re: Do you have any issues with airflow?
>I never have any problems with dry chips. Sucks 'em right out. Wet, stringy chips often need to be stirred up a bit, and in fact some of them may need to removed with a small wooden spoon. Then the hose gets the rest.
I have a fairly large Shopvac. I don't know how well a small one would work with wet chips.
I sometimes turn camphor burl. Until I empty the Shopvac I get a good whiff of camphor every time I turn it on. Smells good.
Wally
Carole Valentine
>I just blow it out with a quick shot from the compressor with my hand at the mouth of the vessel to direct the shavings away from me when they come out. Canned air? You would spend a fortune on it! I was at a friend's house not long ago and her husband had moved her compressor to another building for something so we tried to use a straw... almost useless. Before I had a compressor I used the shop vac.
Shopvac = blower
wilbur
>I have to admit I haven't tried a hollow form yet, but don't most Shopvacs have an exhaust port that you can also attach the hose to, turning it into a blower?
Russ Fairfield
>There are 3 choices. You can blow them out, suck them out, or scrape them out with a wire or a spoon.
The air hose is faster, but it blows the stuff all over. The shop-vac takes a bit longer, but it does a good job, and is cleaner. Scraping them out with a piece of wire is slow, difficult and doesn't do a good job of cleaning it out.
Which you use depends on the size of the hole, whether you have a compressor or shop-vac, and personal preference. A long time ago I used a wire or whever I could poke in the hole because that was the only way I could do it. Now I use the air hose because I have it, but sometimes a wire hook or a long handled iced tea spoon is still the better way to do it.
Jim Miles
>I bought an old cheap vacuum cleaner from Goodwill and keep it mounted on the wall by the lathe, Dosent't put dust in air like compressed air.
bob elliott
>Without the aid of a shop vac or air compressor, this may help. If you have a variable speed lathe that will turn slow enough (500 rpm is way too fast), the shavings will work their way toward the opening and often times fall out. It's not the quickest route, though. This method can be expedited by clearing the opening with finger or utensil.
Allen Neighbors
>I use my air hose with a long narrow nozzle. A fan sitting beside my lathe, directs the shavings down and away, and the dust toward the exhaust fan at the rear of the shop.
Re:My solution is similar to Wally's, but.....
Jamie Donaldson
>... I have attached a 1" dia. aluminum tube to the vac hose that can be used for poking and sucking at the same time. I also drilled a few side vent holes near the working tip that aids in dust removal without clogging, and it sure beats blowing stuff all over the place with a compressor.
