Re: CA Stitches - have you done it?
Steve Russell
>Hello,
Monofunctional 2-cyanoacrylates were first discovered in 1942 during World War II, but were not patented until 1949. In 1951, scientists at Eastman Kodak were working on thermal polymerisation and accidentally discovered the rapid ambient-temperature cure and superior adhesion properties of cyanoacrylates.
While working on a freshly prepared monomer, the Kodak scientists discovered that the glass prisms of their refractometer had become tightly bonded. Extensive research thereafter found many different types of substrates bonded in a similar tenacious manner. The first viable production process did not evolve until 1954. Subsequently in 1958, Eastman #910 debuted, the first commercially available CA product.
Specially prepared cyanoacrylate formulas are used in numerous medical procedures, including heart surgery, eye surgery, ear surgery, cerebrospinal fluid leak repair, skin closure, emergency wound closure assistance in military battlefield conditions (Vietnam saw widespread use by MASH units) and numerous other areas.
However, the common industrial types of cyanoacrylates are not the same formulas used in the medical profession. Typical industrial cyanoacrylates are usually ethyl, or methyl based esters and can produce significant heat during polymerisation. Medical grade cyanoacrylates by contrast, are typically n-butyl-ester, isobutyl ester, or octyl ester based and are specially prepared to cure with as little heat during polymerisation as possible. Excessive heat or rapid cure during polymerisation can lead to tissue necrosis.
Inside the body, these special medical grade cyanoacrylates are bacteriostatic, painless to apply when used as directed and eventually break down harmlessly in the tissue. Once cured, the cyanoacrylate is essentially inert. N-Butyl ester based surgical cyanoacrylates are rigid when dry, but provide a strong bond. Octyl products offer increased flexibility when dried, but reduced bond strength.
Bottom line is that the typical CA's used by woodturners are not made for wound repair. The heat generated during polymerisation may create additional damage to the wound area, which can lead to increased recovery time and scarring of the area. It sounds like you did the right thing getting your stitches and getting the wound cleaned up prior to closure. Take care and all the best to you and yours!
Steve Russell
EWW, WVP
The Woodlands, Texas
